Question about Sony Playstation 3 (PS3) Console
My ps3 slim keeps blowing power supply fuses after about 10 to 15 minutes of it being switched on, i cant even download new software without it going off
gamerfixer07
  • 344 Answers
SOURCE: PS3 Power supply
That will be extremely hard to do unless you are a bench tech and know what all the marking mean on every componant and or have a schematic. I haven't heard of anyone finding the infamous part that is burning out in the first gen of Power Supplies yet either. Good luck!!
Posted on Jun 25, 2008
Reddwolf25
  • 43 Answers
SOURCE: Ps3 blows fuse at plug
Cocodinaro,
It sounds like you're using a damaged power strip; however, this issue can be caused by a bad outlet.
Replace the fuse and plug the unit into a different outlet. If the fuse blows, you need to go to a video game store an purchase a new power strip.
Regards,
Reddwolf25
Posted on Apr 12, 2009
  • 161 Answers
SOURCE: Want to download full content of fat ps3 onto new ps3 slim
Take out the HD of fat, use a adapter to get the info from your HD onto your laptop. Put the HD back in.
Trade in your ps3, take out the HD, put the files you want back into the HD. Put the HD back in the slim.
Posted on Sep 10, 2009
  • 149 Answers
SOURCE: i have saved all my data from my 60gb ps3 onto mem
what type of data if its game saves you accually have to goto game saves on XMB and look in mem stick then hit triangle to copy them to the HDD. videos and other stuff should just show up under videos. basicly everything you copied over you have to goto that area of the XMB to copy it back.
are you seeing the data just not able to copy it or what?
Posted on Sep 23, 2009
SINN3D
  • 85 Answers
SOURCE: i just downloaded new software on the ps3 so i
DOWNGRADE or UPGRADE again
Posted on Jun 20, 2010
How do I know if it is a board or power supply issue?
Without proper test equipment it is hit and miss. I can say that it is most likely the power supply. The only possible way you might be able to check is to unhook the other boards and try again. If it does blow out the fuse then it is the power board. BUT the unit might not power up at all if you unhook the other boards, especially the control board.
Feb 05, 2016 | Emerson 22" Class LED-LCD 720p 60Hz HDTV,...
PS3 asked for update, got to 99% and froze. now cannot even get to safe mode!? any clues?
Strange! Even if the update fails, you should be able to enter "Safe mode"Try going to PSN and downloading the update to a thumb drive via their instructions to do so. Remember that the different types of PS3's have slightly different functions. Like for the older systems(FAT) you have a switch to power the system, whereas the (SLIM) or (SUPER SLIM) do not. A key feature to remember when trying to go into safe mode, is to have your charger cord connected with the controller hooked up. It will not go into safe mode without it.
Dec 07, 2014 | Sony Playstation 3 (PS3) Console
Keeps blowing breaker. have switched outlets (circuits), even exchanged for new one. HB-P100N30AL-S3
Possible that there is a short within , if there is sparking then the magnetron is defective. If not check for shorting in the capacitor, check the mains transformer or the secondary supply. Isolating the circuit will confirm which part produces the short. Please be careful when you work with the power connected.
Jan 21, 2013 | Hamilton Beach HB-P100N30AL-S3 - 1.1 CF...
The fuse keep on blowing after few minute of use in electrolux dishwasher ESl4114
Hi, the most common fault on a washing machine is when the heating element is breaking down it will cause a trip or a fuse to go because it is a "resistive load" i.e a small short circuit.
Try to put your washer through a cold wash cycle if it completes the cycle without blowing the fuse then you know that you need a new element. If it still blows the fuse then you are looking at most likely a motor problem.
Jun 11, 2011 | Electrolux 18 in. ESL4114 Slim-Line...
I just bought a PS3 and it basically does not allow me to connect to the internet. When I go into the menu it keeps loading forever, I waited like one hour and nothing happened. I can reboot it and the...
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
PS3 WHEN CONSOLE SWITCHED ON IT BEEPS THEN TURNS OFF AND FLASHES RED
My guess is its going to die soon. I would back up most of your stuff on a hard drive if possible. If it gets that far. I had this happen to my 40GB PS3 about a year ago. It turned on for 5 minutes then off. Soon after that it didn't turn on. And it was making really loud fan noises.
What are the specs of your PS3 and was it making loud fan noises before? Consider buying a new PS3 slim?
A quick guess that i just thought is try doing the fan test before turning it on. Turn Off PS3 completely (switch in back) Hold eject button and Turn on switch.
NOTE: This is dangerous and can harm the PS3.
Good Luck
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Play station three will not turn on on then off when power button is pushed.
First, old PS3 or new slim PS3?
The old models have a power switch on the back that must be on. You'll know its on if you have a red light on the front of your console.
To turn the PS3 on, press the power button. A light should turn green, and you're good to go.
To turn off the older PS3's, you must hold the power switch down for several seconds. For the new slim model, just press the button quickly.
May 02, 2010 | Sony Playstation 3 (PS3) Console
I replaced the stereo systems and for some reason it keeps blowing fuses ...which even the windshild whipers wont work... i change out the fuses and it will work for a short time and blow out again...i...
If you had someone else install this system and you didn't have the fuse blowing trouble before that, and if the fuses don't blow if you aren't using the radio, then they certainly have done something wrong. See a manager and keep pushing to talk to someone higher up. You might also consider contacting the Better Business Bureau in your area if you can't get help.
Now having said all that, there may be a simple wiring error at fault. Most radios have two fused power lines: one is a constant 12-volt line from the battery (to keep the clock going, remember your last settings, and so on) and the other is a 12-volt line that's switched on by the ignition key. This is the one that provides power when the radio is on, and it's got a higher-rated fuse than the other line. If the installer tapped power for the switched 12-volt line from somewhere that is being protected by another, lower-amp, fuse, the radio may just be drawing more current than that fuse can handle. So, poof it goes and anything else on that circuit goes out as well.
Make sure the switched 12-volt line is supplied direct from an accessory connection at the fuse block in the passenger compartment, or before any other fuses if tapping some other circuit for power.
Good luck, and I hope I've been able to help. Thanks for using Fixya!
Jan 29, 2010 | 2000 Ford Mustang
Cocodinaro,
Regards,
Reddwolf25
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
PCB Fault?
dc power from batteries is switched (inverted) by semi conductors. this involves switching on and off the dc supply buss to create an alternating voltage. if the devices are blown then as soon as the unit is connected to dc the dc shorts outs and blows the dc fuse, this could be your problem. unless you can get a good power electronics tech to fix this for a reasonable price you should recycle this and buy a new one. in some ups systems the dc from the batteries go via a dc up converter which increases the dc voltage to a level the inverter will run at. all this circuitry is difficult to work on and almost all of it is controlled by logic circuits and software.
one last word
batteries are always live and are very dangerous, remove all metal objects watches,rings etc before handling, wear eye protection and take account of all instructions supplied .
with batteries if in doubt the don't work with them.
Nov 08, 2007 | Belkin (F6C800-UNV-PL) UPS System
Sony Playstation 3 (PS3) Console Logo
616 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
