Question about HP Designjet Z6100 InkJet Printer
Hi i have 08:11 erro esignjet z6100 - HP Designjet Z6100 InkJet Printer
  • Linkster Apr 19, 2016
    Try reseting the memory. If that does not work then try one memory stick at a time. 90% of the time it is one of the memory sticks has gone bad. If that does not fix it then replace the hard drive.
Did you manage to fix your plotter after you were getting error code 08,11 as we are getting the same code and can not find the problem.thanks from simon
simon@aided-design.co.uk
Posted on Nov 29, 2010
    New Friend:
Add a Comment:
Posted on Apr 19, 2016
    New Friend:
    Problem Solver:
  • 10 Answers
The fault code is combined see below
08: Front Panel
:11 Reseat/Reconnect/Clean/Adjust (manually)
if the end panels have been removed recently it may just be a poor contact on a connector. or the display will need to be replaced.
Posted on Jan 02, 2013
Why does my HP printer say there is no maintenance cartridge?
When replacing expendable parts like the maintenance cartridge you have to go through the printer internal menu and reset the maintenance count. There is a combination to get to this menu on the printer. You might be about to access the menu through the web interface for the printer. I don't recall this combo but attached is the manual for this printer.
HP Designjet Z6100 Printer series
Feb 23, 2015 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Hp designjet z6100 42:10
error code 42:10
Electrical fault in Carriage Motor or starting the Scan Axis or Homing Scan Axis.:
it is not uncommon to find that the encoder is the fault behind the error code,
in the User manual there is a procedure for Cleaning The Encoder Strip. you should follow these steps carefully
.A Z6100 User manaul is available to download at HP.com link as follows:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?cc=us&contentType=SupportManual&prodSeriesId=3338748
the user manual is located near the bottom of the page
Sep 25, 2013 | HP Designjet Z6100 InkJet Printer
I have a hp z6100 and it keeps saying load roller
Do you mean load up Take up Reel, in which case the Take up reel option can be switched off in the paper menu accessible from the front panel on the Z6100.
Feb 22, 2013 | HP Designjet Z6100 InkJet Printer
Hi I have z6100, just before hour while printing the mashin stop with 86:01 error (Possible paper jam). I tryed several time to clean the encoder strip and all the cells but is not working. I remove the...
Hi, Try taking a damp lint free cloth and cleaning the rails that the carriage moved left/right on. You will probably find the carriage rails are dirty.
When the rails are clean, oil them lightly with silicone oil. You should also squeeze a little oil on the foam pads that are on the left and right of the carriage assembly. This keeps the machine lubricated.
If this does not solve your problem then probably the line sensor on the machine needs replacing.
Best regards
Banner Stands
Aug 16, 2011 | HP Designjet Z6100 InkJet Printer
I have hp designjet z6100, when turn power on it gives empty box on display, and nothing else.
Hi so no error code? I'm sorry to say without an error code to point to the fault is not not going to be a simple job,
I make a living repairing designjets but I'm not supported by Hp, my best advise would be to email Hp and ask for a Maine agent in your area then pin them down to a price to come out and give you a quotation for the repair on your plotter
Yours Ian
Ps if this has been useful please rate me
Mar 10, 2011 | HP Designjet Z6100 InkJet Printer
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
Light and dark banding on HP Designjet Z6100
this could be several issues. clean your encoder strip, clean the contacts on your printheads and carriage assembly. check that you are using the correct media profile. let me know if this helps.
kd
Aug 06, 2009 | HP Designjet Z6100 InkJet Printer
HP Designjet Z6100 InkJet Printer Logo
740 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
