Question about Jenn-Air JCB2282H Side by Side Refrigerator
My refriger side too cold, and the temperture keeping drop even to 24 though I set to 38 F
  • Jenn-Air Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Why does my freezer go to -15 on a daily basis even though its set to 0. Fridge side is fine.
should check ur cold control knob aka temperture thermostat with a multimeter, u did check to see no door seal leaks?
Feb 19, 2015 | Refrigerators
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Freezer & freezer work fine. Water stops when refrige is set at 38 degrees. To keep water from freezing we have to set the refrige temp to 40 degrees, but find that temp not cold enough. Water can...
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Jul 02, 2009 | Samsung RS2556 Side by Side Refrigerator
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Thermostat problem
is the refrigerator section is freezing up
Apr 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Never shuts off.Too cold
Try defrosting.
if you can move everything out unplug ,turn it off w/ doors open 6 to 12 hrs this will free up any clogged tubes. Set it at a low setting and keep an eye on it, If this doesn't work your thermostat may be going out.let me know.Good luck.
Len West
Feb 16, 2009 | KitchenAid KSRS25IL Side by Side...
I am having the problem with the refrige not getting cold enough.
what did ne quote for the repair, and if he did not even look at the commpressor or condenser coil then how could he even diagnos this situation? i owuld go ahead and be sure to fill the refrigerator and freezer due to the fact that then it works less. Just keep an eye on it and you should be fine untill either you have a real tech go out there or if Santa's really nice and gets you a new one. m I wpopuld also clean the condenser coil on the bottom with shop vac and a brush. Merry Christmas
Dec 22, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCB2282H Side by Side Refrigerator Logo
75 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
