Question about NAD T762 Receiver
Intermittend no audio from digital inputs, flicker video monitor out, volume goes up but not down
Lately the T762 has been acting up a bit. First I noticed that the monitor video out started to flicker with grey background as if the vertical sync is out, the OSD menu's almost useless. Then, intermittently, the digital input often stop working (not just one input, but any of the digital inputs that connected to PS3, Sattelite DVR, and DVD via either coax or optical links all exhibit the same behavior) The latest being that the volume goes up, but barely goes down, condition is worse with use of remote controller.
Except the flicker video out, the other conditions do not exist when the machine is cold. After having used for about 45 min to 1 hr mild use (ie just watching tv and relatively low volume) the condition started to show up.
NAD had yet to responde... has anyone had similar issue and if it has been fixed?
  • 1 more comment
  • fixmynad May 14, 2008
    Thanks! i'll try to get to it in the weekend.
  • fixmynad May 18, 2008
    I took a quick look, and found 2 resistors that while seem to be intact, both have the painted cover burned off so that the color bands are no longer visible. I cannot tell if there's anything else that may have been damaged or if the resistors themselves are actually damaged.
    The location of these resistors R811 and R812 are just north of the big round toroidal coil when looking from the back side of the unit. Perhaps that matches the sector of the board responsible for digital input? :)
  • bmitchener Apr 14, 2009
    I have an NAD T762 as well and about a year ago it started having the same problem where the digital channels go out intermittently.  Analog audio works fine but anything connected to a digital input, whether optical or coax, won't play at times.  Often it will work perfect for days or even weeks then suddenly no sound.  I have been living with it for over a year now because of the time and potential cost to get it fixed.  If anyone has a solution I would be very grateful!
  • 4,234 Answers
Since the problem appears only after the unit has been run for a while, I'd be looking for any part close to a heat source. The odd behavior suggests that there is noise on the data lines for the volume control chip and the digital processing areas. Look for a bad 5V regulator +/or bad caps on the 5V line. Also check for poor solder connections in the power supply and final output stages.
Keep us posted.
Posted on May 13, 2008
  • ABRsvcs May 14, 2008
    I forgot to add in the original note a request for the serial number. NAD is known for making circuit changes within a model series. These are tracked by serial number. Please post that as well. I have requested a copy of the service manual for your model from my local NAD source.
    Keep me posted.
Why does it shut off at a certain volume?
this is an internal protection feature, so that your speakers are not overloaded and blown out
Jun 08, 2010 | NAD T762 Receiver
Connecting audio from pc to receiver.
What does your sound card have for audio outputs? Mine (M7250N Media Center) has all the expected 7.1 analog audio outputs AND a digital S/PDIF audio output that I run to my receiver's coaxial digital input.
Even if you have just 2-channel audio on your PC the headphone output can be used with an adapter that makes it conenct to a standard RCA audio cable. Run it to any available Linme Level input on the Denon. Get into your sound controls on the PC and make sure your Master Volume is unmuted and adjust whatever else applies to your machine that may affect the audio.
Your monitor is not really a player in this scenario.
Apr 29, 2010 | Denon AVR2310CI 71 Channels Receiver
First we need to narrow down where the problem is, try using MP3 player or audio source to feed the monitor (set the monitor volume to about half way for now) audio input (green jack), if you do get the sound OK, then the other end of the jack should be connected to the green jack (audio line out) of the PC (set the volume control to half way up) and see if you get the sound. Post back what happen as to which parts do not work.
Apr 12, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
My problem with this screen is that when I try to go to another web site the whole screen starts flickering and I can't go to another web site. Happens once in awhile, sometimes it works great and then all...
Could be a loose cable inside off the monitor. There is a cable that hooks into the back of the lcd and if that is even loose by a little bit it can make the screen act crazy. If you can get the back cover off of the monitor, try to unseat and reseat that cable to see if the problem goes away.
If you do that and it still exists then the lcd is bad and the whole monitor needs to be replaced.
May 02, 2009 | Acer V193w LCD Monitor
Monitor keeps shutting down...
hi im josh in cebu phils. mark the problem centeres in your video card try to check if it is in the proper temperature (not heat or  hot). check if it is seated firmly in the slot.
Feb 24, 2009 | Computers & Internet
Mitsubishi xc-3716c monitor
ttl is in short from Transistor-Transistor Logic.
Apr 18, 2008 | Computers & Internet
NAD T762 - no sound
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Sep 08, 2007 | NAD T762 Receiver
NAD T762 Receiver Logo
271 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
