Question about Refrigerators
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
  • 944 Answers
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Westinghouse virtuoso fridge/freezer has stopped cooling. How do we check the fuses etc? seals on the doors are all fine.
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Aug 03, 2008 | Refrigerators
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
