Question about IBM ThinkPad G40 2388 Notebook
Getting a new lamp
Is replacing a cold fusion lamp an easy thing to do? The underlying question is: is this laptop fixable? I'll try pressing the F keys before set up, I only did it afterward before. Someone else mentioned that the "screen card" might be the problem--what does that mean?
  • 101 Answers
NO replacing the Cold Fusion lamp is NOT EASY if your are not experienced with these do not try it . YES your laptop is very much FIXABLE . When you see the POST PROCESS on your screen then you press Fn key at the bottom left hand corner keep it depressed and then press the function key with the computer icon 2 times - first time switches display to external monitor only , second time to both LCD and External monitor. Actually for LCD screen to glow a small thin fluroscent lamp is used which requires a high voltage of about 150-200volts that is generated by this so called screen card - the correct name Invertor PCB or board.
Posted on May 13, 2008
Battery keeps dieing even after changing it twice.jump starts no problem.airbag light stays on aswell.
1st thing to check is where the ground battery wire attaches to the frame of the car - sometimes they get loose and don't make a good connection anymore (if so, just tighten it). You could also look for obvious problems with both battery wires (insulation worn off etc).
On my Civic, the airbag light will go on after the battery is taken out (or dies), and it has to be reset manually. It's easy to do, but at a dealer they'll charge $50-$100 for it. I have no idea if a Ford Fusion is the same way though, so you could check some car forums or just shell out at a dealer where you can be sure they'll fix it.
Sep 28, 2012 | 2010 Ford Fusion SEL
Analog Clock in Ford Fusion 2009 has no more light
Remove the instrument panel center finish panel by gently pulling rearward using a small thin prying tool such as a small putty knife. This will release the spring clips. Disconnect the electrical connection to the clock. Near the top corner of the rear of the clock is a small lamp assembly that screws out. Mine had a black plastic base but the one I replaced it with had an orange base. I ordered an Audi/VW part #4A0919040C as it was substantially cheaper than what the Ford dealer wanted. When you remove the lamp, you will notice the bulb has a green skin over it. You want to try to remove it carefully so you can re-use it on the replacement lamp. The best way to describe it is that it resembles a minature condom. I soaked it in some soapy water to loosen it up and make it easier to remove. A little soap also helps when you place it on the new lamp. Replace the new lamp, re-attach the power and press the instrument panel trim back in place and you are good to go.
Feb 09, 2012 | 2009 Ford Fusion SEL
Have a old maytag want to know if its fixable for cheap model LAT8414AAE will final spin but no water is coming out yes the water is on and its getting power help!
when it goes into the final rinse the washer just uses cold water no matter what you have the setting on, start the washer and flip the setting to cold,does the water come into the washer?try it on hot and check that,if no water coming out on one of the settings do this shut the valve off to the water that feeds the washer,mark the hoses so you'll know where they went and disconnect them from the back of the washer,stick them into the washer or a sink or bucket and turn the water back on,if water is coming out of both hoses you'll know the trouble is just with the washer and i'd say the cold water solenoid on the water valve on the washer is bad and you'll need to replace the valve.
Apr 23, 2011 | Maytag Washing Machines
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Space bar dosnt work unless Ireally press hard is this fixable.Toshiba Laptop
its a fail on the keyboard, you can get just the key on ebay check your model number and ebay it, is easy to replace and cheap
Fosg2000, Rate me please
Apr 26, 2010 | Toshiba Satellite A105 Notebook
2006 ford fusion brake calipers
If it don't press in with a c-clamp fairly easily it is seized and needs replaced.
Mar 01, 2010 | 2006 Ford Fusion
Samsung hlt5076 replace lamp still no pic lamp
If you have home insurance you can claim repairs under "Fusion" But the work has to be carried out by a licensed repairer who provides an account that clearly states that your unit suffered fusion. contact your insurance for a claim form and dont mention lightning
Parts and some labour are covered depending on the policy. Cheaper than doing a X Y board replacement yourself
Sep 05, 2009 | Televison & Video
Help!!
when this happened on our unit (it was still under warranty) replacing the lamp fixed the problem. a new lamp unit seems to run about $250 on the web and is easy to replace from front of unit.
Apr 19, 2008 | Panasonic PT-50LC13 50" Rear Projection...
IBM ThinkPad G40 2388 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
