Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Hef 26 electric fire place the flame reflector light on but there is no flame pattern?
4 Suggested Answers
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 6 Answers
SOURCE: pyromaster electric fire place motor for flickering flame
Test the motor first with a 9V battery. If the motor turns it's most likely a defective Flame Speed Control circuit board PN 10001589.
Contact Southwest Fireplace
11921 S 80th Ave
Palos Park, IL 60464
708-448-3883
  • 4736 Answers
SOURCE: i have a pyromaster hef
If you're not getting any flame effect or only a portion of it. One or more of the 60 watt small base chandelier bulbs is burned out. Replacing one or more should solve your problem.
Posted on Apr 14, 2011
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Should the igniter fire constantly?
Hard to answer the question with out the make and model information. Generally heaters that use an electric igniter in place of a pilot light only fire the igniter until the flame is sensed. If it keeps firing after that then the sensor that heats up to tell it the flame is lit could need replacing.
This link might help you understand it better.
How to Keep Your Electronic Ignition Furnace Working Properly
Sep 08, 2015 | Heating & Cooling
I have a pyromaster hef 337b electric firelplace. The flames do not flicker at all. The motor works, we tested it. Any other suggestions? Where could we find new parts for it
Apr 14, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Oct 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
124 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Steve
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
