Question about Vidal Sassoon 21PC Hair Clipper Set Hair Trimmer
Where can I buy a replacement #1 attatchment?
    Scholar:
  • 192 Answers
Sally's Beauty Supply, they are all over the nation, even on line, check out ebay
Posted on Sep 06, 2010
  • rgirman Sep 07, 2010
    Already tried there, they don't carry Vidal Sassoon
Where to attatch back straps?
Please contact Graco directly for assistance
Jun 01, 2014 | Graco Nautilus 3-in 1 Car Seat
Tip
How to replace your ipod battery
1. buy a new battery
2. open ipod (where it joins up) with thin pice of plastic or metal
3. there will be clips holding then together. push them in and they will open.
4. open ipod carefully because there a ribon cable holding each side together
5. carefully remove the hardrive, (should have a rubber protection around it) by lifting the cable socket.
6. removie battery carefully with thin plastic or metal. try not to touch the circuit board underneath.
7. disconnect wire from ipod case. (pull them from socket)
8. attatch the new battery
9. put back in hardrive
10. put case back on and your all set.
on Feb 17, 2010 | Audio Players & Recorders
Hose under car for radiator popped off so when you put coolint in it just leakes out and causes car to overheat
either needs to be replaced or it is missing its clamp to hold it attatched to the lower part of the rad. buy new clamp and re-install
Sep 19, 2013 | 1998 Pontiac Grand Am
What does p1171 code means and what needs to be replaced or repaired
Buy a can of Mass Air Flow cleaner. Clean your air flow meter which is attatched to the air box. If you have access to a scan tool look at the live data and under Mass Air Flow it should read 14kg/h. If it is at 16 to 20kg/h it is too high. If your tool reads g/s it should be around 3.75g/s to 4.00g/s. I chased this problem for weeks trying everything.
Feb 09, 2011 | 2001 Volvo S60
Need to put in ac refrigerant
hi, you are looking for a 1/2 " aluminum tube (or painted black), when you find that, follow the tube until you find an attatched, rounded cylinder/tanks with wires attatched, when you find that, look for a blue plastic cap, if cap is present, that is your connector! if no cap present , the connector is approx. 1/2" wide, 1-1 1/2" inches tall and attatched to afor mentioned tube near tank/cylinder (actualy called receiver/drier)....good luck, marty
May 27, 2009 | 1999 Lincoln Town Car
Problem attaching a CCd camera to laptops
Usually all cameras & peripherals connect to a laptop using USB or a Firewire port. Almost all new laptops carry USB ports, some have firewire too. Otherwise USB can be converted into firewire using a convertor. Just check the connectivity of your CCD camera and take a decision accordingly. Bye Vishal
Sep 24, 2007 | Cameras
Vidal Sassoon 21PC Hair Clipper Set Hair Trimmer Logo
254 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
