Reg: previous...!!! Hi, I am quiet new to this :). But I want to try. How to remove the hard disc? If you can give me some sort of instructions I will do it. And as I understand, Just remove the hard disc and put it back again and start the system...is it? Thank you... Regards, Vipin Kumar
  • 101 Answers
On the bootom of your laptop you will find icon of HDD secured by 1 or 2 screws , unscrew these and slide out the hard disk . REMEMBER TO DO ALL THESE STEPS ONLY AFTER YOU DISCONNECT YOUR LAPTOP FROM ITS AC ADAPTER IF YOU KNOW HOW YOU COULD EVEN REMOVE THE BATTERY FIRST . When you are removing the HDD out notice carefully the way its was inserted because when you replug it back into its slot you HAVE TO DO SO CORRECTLY ELSE You will end up damaging the HDD AS WELL AS THE LAPTOP. Handle the HDD ONLY by its SIDES DO NOT HOLD ARE APPLY PRESSURE ON ANY OF ITS FLAT SURFACE. Read fully and follow what I have typed here . DO NOT BLAME ME FOR ANY OF YOUR MISTAKES.
Posted on May 13, 2008
How to Format & erase owner account without accessing the operation system of this product below?
Hi Mr. Khaled...
Thank you for choose the Fixya...
Kenwood music system are having the facility to reset the old user data from "Hard Reset" button, try to hard reset (Hard reset should delete the all data in Music system)
Kindly check the below link
Kenwood KDC BT30 Instruction Manual Removing The Faceplate How To Reset...
if it not solve your problem please send me your Kenwood music system model number so it is batter to find good solution.
Thanks
Prashant
Apr 20, 2016 | Computers & Internet
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
Trying to find the size or code for brake discs without having to remove the wheel.
http://www.eurocarparts.com/brake-disc will give you a list of suitable parts for your car along with sizes if you enter the reg number. This is of course if your car is standard. Alternatively phone renault http://www.renault.co.uk/ownerservices/servicing/parts/
Oct 07, 2014 | Cars & Trucks
Why does my Acer laptop sound like it's taking off ! There is a whirring noise form underneath on the back left, i thought it might be the fan but it starts as soon as i turn it on but after some time it...
Hi Ian check to see that you have not left a CD disc in the CD rom /dvd drive--- sometimes they will cause this sort of noise on start up when the computer is looking for an operating system it may look in the cd drive first and scan the non operating system disc before booting from the hard drive
I hope this helps
Andrew A
Mar 28, 2011 | Acer Aspire 5535-5050 Notebook
Why does my xbox say disc unreadable , and tells me to clean the disc when it is a new game , that i was playing previous to the console giving me instruction to clean the disc ?
You laser eye inside might be dirty try blowing it out and if it doesnt work bring it to best buy and they will use a air compressor to clean it for you.
Feb 14, 2010 | Microsoft Xbox 360 Console
Maytag Quiet Series 200 Handle Broken
Remove the torx screws around the inside of the door and pop off the inside cover. Remove two screws and unplug handle. Remove broken handle. Insert new handle and replace screws.
Sep 20, 2009 | Dishwashers
Ducati 749 Brake Judder?
Plenty of tales about warped discs to go with that one, but it seems that it can be fouled-up disc mounting bobbins - the dust and crud get in and stop them from "floating". try a small bolt thru the bobbin with a nut to lock it, then spin it while spraying with brake cleaner (or soapy water) and you'll free the bobbins off thus restoring the flex and float.....worked for me. Quite a bit of dust and muck come out....try grasping the disc and see if it does actually float on the bobbins before and after
Nov 20, 2008 | 2005 Ducati 749 Dark
I have a 2003 Santa Fe (approx 71K miles - new brakes in March 2007) that has been making a low pitch sort of squeal when I am accelerating between 15 mph to 40 mph. Getting more frequent and sometimes at...
Either the caliper pins are not releasing properly(cleaning and lub. will solve that) thus causing brake pads to partially stay in contact with your brake disc(rotor)
or its possible that your brake discs have exessive riges on the outer ege(if spec. allows discs can be skimmed or replaced)
also try shamferring the brake pad eges and remove forreign dust/dirt particles from and arround your calipers.
Jul 23, 2008 | Hyundai Santa Fe Cars & Trucks
Panasonic dmr-eh75v dvd won't work
dirty lens, broken ribbon connections or adjust the bias of the lens place at the back of the lens.....
May 08, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
