Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
No water imput. ge profile dishwasher. PDW9280J00SS. TRIED HITTING THE FLOAT COVER.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 07, 2010
GE PDW9280J00SS not draining. I have read other posts that say this is a "water level sensor problem" but that doesnt make sense since it FILLS to the proper level. After cleaning cycle, then it...
GE dishwashers use either a drain solenoid or a separate drain pump assembly. Sounds like your drain pump isn't getting power to it until you start other cycles, which sounds like control board issues.
Sep 25, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Not getting water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Nov 27, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher has no power and am hearing A constant highpitched noise
i do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
Jul 09, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher
Check your float in the front left corner it may be stuck in the up position and making the dishwasher think is is full of water already.
Oct 29, 2007 | GE Profile PDW8000G Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
321 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
