Thomson Lyra PDP2842U MP3 Player Logo
Posted on May 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Any suggestions to help so I can use please
The mp3 just shows the thompson sign and does not initiate or read on my computer.
  • wwwjf Jun 28, 2008
    exact same problem. only had it for few weeks. was a replacement for another which did exact same thing. I think these things are faulty.
Anonymous
Level 2:
Sergeant:
  • Expert 209 Answers
  • Posted on May 13, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
209
Questions
Helped
100558
Points
670
Dear rthawk
I reckon there could be a driver issue here with your MP3 player. I have seen a case with a vendored model that was aquired from Tesco, and in that situation, a driver file was accidently deleted from the MP3 player. Now this matter (if this is what happened to you) could be difficult to deal with, as how do you get the driver file back on to the MP3 player if your computer will not allow it to recieve files? The answer here could be to run the "found new hardware wizard" which is in windows xp under START>MY COMPUTER>CONTROL PANEL>ADD NEW HARDWARE. when you click on the add new hardware, ensure that your MP3 player is plugged into to a USB port which is in good working order. Now if you computer is asking you for a drivers disk, then insert the CD into a drive bay (CD that would have been despatched with your MP3 player) and follow the commands.
Now if this still does not resolve your problem, you could always try to format your MP3 player using the utility within windows. To get to the utility you have to follow this. START>MY COMPUTER>right click on MP3 player drive letter>PROPERTIES>FORMAT VOLUME. This will format the entire USB MP3 player and create a partition on it which can either specified as FAT32 or NTFS, and will format it accordingly to which of these you choose. HOWEVER, a slight word of warning here, doing this could inadvertantly kill off" your player totally, as to the point it could only then be used as a pen drive instead of a MP3 player. It is possible that your computer (and any other computer for that matter) would only recognise the player as a pen drive, but even here, i would say it is still possible to flash your MP3 player and force the driver file back onto the player.
Now if this has still not worked, there is a danger that you could have corruption within your own computer, so here, you can try using another computer to see if you have the same problem. If your coputer ios found to have an issue, then this is mostly likely to be software based, and specifically relate directly to the system registry, as this is where the majority of data corruption will occur. Now if this proves to be the case, just swan off your operating system after backing everything up, format your drive, and re-install windows.
Now before attempting any of this lot, i would suggest by starting off at checking things like blog sites and forums in order to see what other people have done about the issue relating to your manufactured/ vendored model of MP3 player, but the list of potential solutions above are things that I have done, and these seemed to work for me, but like I say, go and check those blog and forum sites and then choose the best solution based on what the majority of people EXACTLY say.
Now whichever of the above approachs you take, or even if you find something else entirely, please do leave me feedback on this, as so i will then have knowledge about hw best to deal with this in the future.
For now though, i do wish you all of the best of luck on this one, and do take care of yourself,
kindest regards,
Yours sincerely
Oz
4helpful
Computer says my rca thompson pearl has files, but none when on?
try formatting it but when the format window pops up (for me this worked anyway) make sure that the file system is set to FAT (default), its how i did it and i had the same problem now i'm listning to my music :]
Mymusix mp3 PD 6070 1gb version
Only follow the advice I am about to give if you have read the company's website/manual and done troubleshooting with them first. This is complicated and is more of a last resort sort of thing:
Unplug the mp3 player, uninstall the MTP Device on your computer, and then replug the Mp3 player. Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> click on plus sign next to Windows Devices (wording varies from computer to computer - click on every plus sign if you can't find it) --> double-click on MTP Device --> Uninstall
-Tha Mp3 Doctor
5answers
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Thompson lyra 2gb mp3 broken or not?
Mine froze on the blue screen when turned on. BSOD???
Plugged it into the USB on computer and it all came good.
2answers
if u haven't tried using the installation disk then try with it and see
1helpful
3answers
SanDisk Initializing
4answers
RCA LYRA MC5102A
Had same issue with mine, right out of the box!  I called support, they sent me to some 3rd party support company...  That place told me to return to vendor.   Thompson Support.  They basically just tried going to the RCA website, found nothing there, and finished up with return to store...
Mp3 digital player
Hi!
Don't worry, that's not a problem...unless it appears every time you plug it in.
Well, when it usually connects to the computer, it should be able to read it unless the Sony NW-E405 has a corrupt data song. In other words, you can either format the mp3 player on the mp3 player itself or on the computer.
By formatting on the mp3 player, it has be on either pause or stop button. Play button will not open the Initialize menu.
So go to menu, settings, scroll down to Initialize, and then click format. It should say OK?
click yes.
A quick Format done screen should pop up.
The computer way is much longer but cleaner.
Go to my computer.
Right click the removable disk (or it would say whatever you named it to be)
and click format.
A screen should come up with some info like capacity and File system.
Forget all that and click Start.
It should probably take 2 minutes.
Then try it once more.
It should be no worries now.
If it consists to be a nuisance, please reply back
I'd be more than happy to help fix this.
Have a great day!
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
