Question about Intertherm P3RA-060K Air Conditioner
Fan is making a squealing sound, - Intertherm P3RA-060K Air Conditioner
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
My Frididaire upright freezer is making occassional squealing and knocking sounds. model FFU14F5HWN. Any ideas?
Sounds like a compressor or a condensing fan motor. If it is the fan motor most of the local motor supply houses carry them.
Nov 01, 2014 | Freezers
Radiator fan stays on high so when driving it sounds like a bus have been told its a viscous fan so no wiring to activate it, and when i rev to hard you get a squealing as if the fan belt is slipping.
Fan clutch is defective. At high RPMs the fan is harder to spin, hence the squealing sound. Replace the fan clutch and you should be good to go.
May 15, 2011 | Kia Sportage Cars & Trucks
Alright whenever i turn on my heat or air in my car it makes this loud sound like.....eeeeerrrrrrr on all settings what is wrong with my car?
This is generally a sign of the fan going bad. The magnetic charge in the fan when it goes bad makes the squealing sound. It may have to be replaced soon.
Nov 28, 2010 | 1992 Oldsmobile Cutlass Ciera
Squealing sound
The belt is the most probable cause.
What else it could be?:
Bearing failure.
Alternator failure.
RECOMENDATION:
Replace the Belt with a new factory original belt.
Hope this tip helps.
R/
David
Feb 14, 2010 | 2001 Ford Focus
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
2003 subaru forester makes noise when airconditioner comes on. Is it the fan belt
What kind of sound? If it squeals then the fan belt needs tightening or replacing.
If the sound is the engine increasing in speed when the compressor engages then that's normal.
Jul 02, 2009 | 1998 Subaru Forester
Squealing oven
there is a separate casing fan hidden out of sight and this is what is squealing.
take oven out, remove top and back panel and you can see the casing fan. try wd40
Sep 17, 2008 | Neff B1641 Single circotherm super...
Intertherm P3RA-060K Air Conditioner Logo
22 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
