Question about Broan-NuTone Heating & Cooling
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link: http://www.centralvacuumstores.com/nutone/Broan-Nutone-Heater-Elements/QTXN-Series.php
Hope this helps!
Posted on Nov 15, 2012
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
Amp draw on #SMA-64140A
At which voltage?
If you have 120V to it, 4,000 watts is 4000 / 120 = 33.333A.
If you have 240V, 4,000 watts is 4000 / 240 = 16.667A.
Dec 11, 2013 | King Electric Heater. 4,000-Watt Fan...
Dear sir, I have an Heritage ceiling fan art.nr.
blue and red are your power or hot wires green/yellow would be ground you need a netrual it will be white or gray color.good luck
Aug 28, 2011 | Heritage (4AXW42PB1S) Ceiling Fan
Our heater worked when shut off 6 mo ago, it doesn't heat at all now when we turned it on. the reset button was not out, we pushed on it. the power at the circuit breaker is on, any suggetions
by looking at pitcher you have a 40 gallion hot water heater
check thr voltage at the heating elaments
ok remove the two blue covers in thare you
will find a square box with two wires check the
voltage on the round peace it looks like a big nut
with two wires on it use a multi meater you will
have 110 volts if you do the heating elaments
have gone bad
thats a new ballgame you will need to drain the unit
turn the power off
take the two wires off the round peace once they
are off you will need a big sockett un screw them
out both of them take them to home depot and match
them to your new one make sure thay are the same
make and model once you are satisfied reinstall them
please rember to refill the unit with water if you dont
the new heating eliments will burn up in 2 to 3 seconds
hope this helps you
bob
May 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The light on my hunter ceiling fan flashes on and off when I turn it on. I have a model 21421-530 Type 2. Any ideas what might cause this? Ceiling fan works fine on all 3 settings, so I don't think it's...
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
Jan 19, 2011 | Hunter 52" Ceiling Fan With Light And...
Just installed heater, turned it on and nothing happened. checked voltage and had 118/119 at l1 and l2 inside heater. removed heater and disassembled, checked wiring against schematics in manual and was...
Im.sure there is safeties on access panels. Put it back together and try again. Be sure you have removed all packing material!! Your element should begin glowing in seconds.
Aug 14, 2017 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 724 heater7500 w 28x32x10 garage with dog door it will only keep garage at 40 degree not 50 like i want in minnesota what are my options
The heater is too small for the space you are heating....
You need to get a second heater or get a bigger heater to get more heat...
Heatman101
Nov 30, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
Nutone, Model QTXN 100HL-A 1500 Watt Does not heat. Electrician said it was the heater part that has "6260 Eichen 04" on it. He said it was the diode. I would like to order the small part.This is a...
The "diode" that your electrician mentioned is actually a one shot thermal fuse.
You can either go to the Nutone website for parts, or remove the thermal fuse, extract the info written on it and buy a replacement. Mine was a 100C 10A thermal fuse. I got mine from DigiKey.
Mar 29, 2010 | Broan-NuTone Heating & Cooling
New heaters need to do a start up or testing for proper operation model f2f5103n TPI corp. Industrial type heater
When you are ready to test run the unit you should take an amperage draw reading on the elements.
The formula to see if the elements are drawing the correct amps is: (voltage x amps=watts) example: If a heating element is 1500 watts and your voltage is 120 volts, then your amps will be 12.5 amps. (120v x 12.5A=1500W)
The easiest way to check amp draw is with a clamp on amp meter.
Nov 24, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Heating & Cooling Logo
862 people viewed this question
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
Paul Carew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
