I have a faulty on/off switch on my front loader.
  • purdy1111111 May 14, 2008
    My washing machine is a Westinghouse LF652D. When I push the on/of button it does not always connect. Can you please tell me if there is something I can do?
  • eric bosman
    eric bosman May 11, 2010
    ? Than either replace it or give me your model number and brand name
  • 487 Answers
If you are in australia please call the number in the link for part number and replacement switch. Just put a new one in
http://www.westinghouse.com.au/locator/search/service
For UK or NZ service google westing house UK or NZ
good day or kia ora
Posted on May 14, 2008
The door on my lg washing machine will not open even when indicator light goes out
top loader or front loader
faulty door lock safety switch
unplug from wall .. if no luck
going to have to force it and replace the damaged parts
Jan 22, 2017 | LG Washing Machines
Not spinning for washing machine
Will need a model # to answer fully. No spin could be from clogged drain hose (hose between drain and pump) faulty pressure switch, timer, or lid switch (if top loader) door switch (if front loader.) Most likely clog or door switch, but need Mod#.
Jan 06, 2013 | Washing Machines
My front loader does not get no water in it
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
Oct 24, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have a maytag netune front loader washer- 10 years old. It is giving me an message FL when I go to start it. I can turn it off and try again and it will work fine. Am I headed for bigger problem?
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
  • faulty door lock solenoid
  • loose wire connection
  • faulty door lock switch
  • faulty door lock sense switch
  • bad control board
Here is a link to the manual for your machine also.
Jul 27, 2011 | Maytag Washing Machines
Front loader won't spin, just after 2 mins up into the cycle it comes up with message le. Can you help please?
Hi just read your posting.Now I need to know the make and model of your machine.It sounds like you have an LG front loader.LE on the LG front loaders means your HALL SENSOR which is attached to your motor is faulty.Please reply with model number and I am sure I can help you.Looking forward to your reply.
Sep 11, 2010 | Washing Machines
Front door won't open at end of cycle
There is a safety switch on the door on front loaders which acts as a time lock. You have to wait a few minutes for it to release, if it does not open after about 5 mnutes the safety latch is faulty.
Dec 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have DE progamme fault...
dE - Door (Front Loader) or Lid (Top Loader) Open Error = Close Door / lid
If error persists, check:
  1. Make sure the load is not too large - try taking some laundry out and see if the error persists.
  2. Wiring harness
  3. Door / lid switch assembly
  4. Unbalance switch
  5. Circuit board for defects.
  6. Check Drum retainer springs are situated correctly and are correctly tensioned.
  7. Make Sure Drum stabiliser struts are not misaligned or broken.
Repair / Replace faulty part.
Nov 06, 2009 | Samsung Washing Machines
LG Tromm front loader-FE error code
The water overfills due to a faulty water valve. The valve needs to be replaced.
Sep 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Overfowing
If your machine is a front loader it could be leaking from the door if the gasket is not properly on. If its a top loader then it could be overfilling due to a faulty water level control pressure switch. Need yo know which it is.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
