Question about HP LaserJet 5550dtn Printer
Standard out put full remove all paper from bin
    Genius:
  • 1,089 Answers
If you have removed the paper from the output bin at the top of the printer and the message won't go away, either the sensor is bad or the actuator is stuck in the up position.
Look at the top of the printer at the rear right of the fuser. There should be what looks like a plastic rod(usually black in color) with plastic "flags". It should be free, moving up and down with your finger. It is used to guide the paper into the bin. What usually happens is the rod gets jammed in the up position telling the printer that the output bin is full. If your printer has this problem, just push the flags down to free it. This should fix your problem. Sorry but I don't have a 5550 in front of me, so this is from memory.
Good Luck
Posted on Jan 11, 2011
I Got the same issue.
Simply check the Output Bin (The tray in which the printout comes after printing ), check the Black Flaps mostly the left side flaps are bit upward in position in respect to the right one. Kindly push them downward and it will start printing.
Thanks Adnan.
Posted on Oct 10, 2012
  • 49 Answers
SOURCE: standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Posted on Feb 27, 2009
jaylex
  • 417 Answers
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Posted on Jan 13, 2008
SOURCE: lexmark Optra T614 " Remove Paper Standard Bin".
I had the same problem and it was driving me nuts. Turns out it was nothing more than the little flap that hangs down at the left hand corner of the output tray. It was stuck in the up position. After resetting it I had to cycle the power and everything is copacetic. Hope that helps
Enduvall
Posted on Apr 24, 2009
  • 320 Answers
SOURCE: The screen reads remove paper standard bin. We
if your getting a standard bin error this is caused by the flag on the top of the printer where the paper comes out or the sensor that it triggers. look to the far left where the paper comes out you'll see the flag make sure it moves freely if it does replace the sensor
Posted on Nov 01, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: standard top bin full remove all paper from bin
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
Posted on Nov 25, 2009
Printer shows standard top bin full
Where the paper exits, there should be black tabs that lift up each time a page exits. They might be stuck in the up position, or possibly broken. Usually caused by aggressive removal of a paper jam.
Sep 24, 2014 | HP LaserJet 5200 Printer
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
Remove paper from standard output bin there no paper
Maybe the paper exit guide is stuck or loose. Here's an article on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aygJz1. Follow the instructions. Thanks
Aug 04, 2010 | Lexmark E450dn Laser Printer
MESSAGE ON THE SCREEN IS: REMOVE PAPER STANDARD BIN
Here's an article in the Lexmark website on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/do0N3V. Read thoroughly and follow the instructions. Hope this helps. But if problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 28, 2010 | Lexmark E350d Laser Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
Standard top bin full remove paper
Greets!
Feb 26, 2009 | HP LaserJet P3005 Printer
Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Jun 27, 2008 | HP Color LaserJet 2600n Printer
Thanks J
Jan 12, 2008 | HP LaserJet 2420 Printer
HP LaserJet 5550dtn Printer Logo
960 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
