Question about Esky 6 Channel Helicopter R/C Transmitter
Big lama wont lift off afters crash just spins in circle
3 Suggested Answers
SOURCE: Lama v3. going in circles
looking from the above top roters should rotate anticlockwise bottom roters should rotate clockwise also check blades are fitted right way round. I only sugest this because you have replaced the 4 in 1 and could have put on connections wrong wa round easy mistake good luck
Posted on Nov 14, 2008
SOURCE: lama v3 spins counter clockwise with no lift off
WOW! I have experienced the same spinning action . . all new parts etc. I have repaired 6 Coco's but this one has ate my lunch . . . when you power up it spins to the left . . . the more throttle the faster it spins . . have changed the 4 and 1 also and adjusted . . . over and over . . . does the 4 in 1 control the rudder action?
Posted on Feb 14, 2009
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
I BOUGHT TWO HELICOPTER FOR CHRISTMAS FOR MY TWO SONS. THE ESKY LAMA V4 AND THE BIG LAMA. THE BIG LAMA WORKS GREAT AND FLIES WELL, BUT THE ESKY LAMA V4 ACTS STRANGE. WHEN YOU CONNECT THE BATTERY THE SERVOS...
I have exactly the same problem. It used to work fine for a long time but all of a suffen i got this problem. Do not yet know how to solve it.
Carl C
Jan 09, 2011 | Esky Toys
Crashed hard and now the bottom rotor is not spinning as fast as the other two. What should I do?
loosen the body screws. lift the right side front so you can see the engine gears, The little gear has slipped on the shaft and is not making contact with the big gear (white plastic gears). Slide the little gear down the shaft so it meshes with the bigger gear. Close the body back up (don't tighten screws yet). Turn the Heli on and make sure all is well (while holding the body closed). Tighten screws...Enjoy...
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
My 9053 volitation wont lift ground, i checked top blade it's not loose from metal shaft, it also wants to spin heavy to the right in circles. I just it so I'm learning
Had a similar model lasted 10 mins i broke this little plactic holder that seperates the blades i bent it the slightist bit and boom never flew again
Oct 16, 2010 | xheli 9053 Outdoor Volitation Metal...
Lama v3 spins counter clockwise with no lift off
Jan 30, 2009 | Esky Honey Bee King 2 RC Helicopter
Nov 12, 2008 | Esky Honey Bee King 2 RC Helicopter
Esky 6 Channel  Helicopter R/C Transmitter Logo
76 people viewed this question
Top Esky Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Esky Toy Expert? Answer questions, earn points and help others
