Question about HP Pavilion dv1000 Notebook
Three errors recently occuring, causing som problems
1. On start up the notebook sometimes gives the message "windows default profile is being loaded, your personal profile cannot be loaded due to insufficient systems resources". If I again restart, sometimes my personal profile will be loaded OK, but it is intermittent? I am running Win XP Home with all the service packs (this came pre-loaded with the notebook) and run Trend Internet Security Pro, so I don't suspect a virus or other such issues on the machine. I have however recently upgraded to Win IE7 and don't recall I had this problem prior.
2. Also on this laptop, I cannot "view" any other PC's on our local network, when I try to "view my workgroup computers" from "my network places". Might be un-related, but this started happening around the same time.
3. Finally on start up I sometimes get an error message "EABServ.exe the application failed to inialize properly (Oxc000022)" Click on OK to terminate application. By doing this is certainly clears the error message but I don;t know what this application might be or how i remove it if it is indeed a genuine program
  • Anonymous Jan 09, 2009
    the instruction at "0*42fb1fa0* referenced memory at "0*02ad544c". the memory could not be "read" click on to terminate the program
I have an error oxc000022
Posted on Nov 20, 2008
My problem is that I'm getting an alert when trying to change my default browser to Mozilla Firefox. The alert reads Application error has occured (Oxc000022). How do I overcome this obstacle, so that I can successfully reinstal the updated version of Firefox?
Posted on Oct 09, 2008
    Master:
  • 441 Answers
Try to remove that on the boot.ini on your system.
You can do that by following this.
1.Click Start>Run>type "msconfig" (without the "") then press enter, On the new window that will comes up that is the msconfig window.
2. uncheck the EABServ.exe on the startup or on the boot.ini. then click apply and restart. I'm not sure if the EABServ.exe is a virus or a malicious file that is not recognize by your antivirus but I know its not a microsoft application.
Posted on May 13, 2008
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
When I turn on my laptop a windows boot manager page comes up.it says: windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows...
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
May 20, 2012 | Toshiba Computers & Internet
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
Try hitting F10 to do a system repair, it should hopefully repair your startup problems. If successful, update your Anti-Virus software and do a complete systems check.
Aug 29, 2010 | ASUS Eee PC 4GB Notebook
My hp laptop wont change desktop background.
The Indexing related issue occurs if one of the device driver is corrupt or not updated. Did the issue occur right after you installed the system, or it started to occur recently? If it occurred originally, the hard disk may not support Win SAT. You may need to contact the manufacturer of the hard disk to confirm this situation.
If it started to occur recently, Kingv84, please let us know if you have installed any disc maintenance related programs. If so, please remove it and check the result. If the issue still occurs, I suggest that you boot in Clean Boot Mode.
Clean boot
Let’s disable all startup items and third party services when booting. This method will help us determine if this issue is caused by a loading program or service. Please perform the following steps:
1. Click the Start Button type "msconfig" (without quotation marks) in the Start Search box, and then press Enter.
Note: If prompted, please click Continue on the User Account Control (UAC) window.
2. Click the "Services" tab, check the "Hide All Microsoft Services" box and click "Disable All" (if it is not gray).
3. Click the "Startup" tab, click "Disable All" and click "OK".
Then, restart the computer. When the "System Configuration Utility" window appears, please check the "Don't show this message or launch the System Configuration Utility when Windows starts" box and click OK.
Please test this issue in the Clean Boot environment, if the issue disappears in the Clean Boot environment, we can use a 50/50 approach to quickly narrow down which entry is causing the issue.
For more information about this step, please refer to the following KB article:
How to troubleshoot a problem by performing a clean boot in Windows Vista
http://support.microsoft.com//kb/929135
If the issue still occurs in Clean Boot Mode, please let us know if the computer is from computer manufacturer.
For the desktop changing issue, please visit the link
http://support.microsoft.com/kb/327998
Jul 10, 2010 | HP 530 Notebook
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Oct 02, 2009 | HP Compaq Presario V6000T Notebook
A disk read error occurred
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
Error messages
one reason for the GWUtil97.dll error is:
  • A DLL file that was needed for more than one program on your computer was accidentally deleted when you uninstalled an unused software program, and now the program that needs that file can’t find it.
  • A new software application has been installed on your computer and it wrote over top of the DLL file that another program needs. Sometimes the version that has replaced the old DLL file isn’t compatible with the older program.
  • Sometimes software installs and uninstalls don’t work the way they should and a DLL file gets damaged or corrupted.
  • Malicious spyware or adware software has been secretly loaded on your computer and is messing about with your Windows DLL file structure. *Recommended: use this free download anti-spyware scan to see if you’re infected.
  • Occasionally, your computer has a hardware part that’s dying, like a hard drive or RAM chip and your DLL files are being mixed up or corrupted as a result.
  • Damage to your Windows Registry is affecting the way your DLL files operate.
then 2 problem with user log in-
to fix do this go to 'C:\Documents and Settings\USERNAME' , where USERNAME is your user. Then right click on the folder and go to 'Sharing and Security...' Click on the security tab and make sure that SYSTEM has full permissions. If SYSTEM is not there, add it and then give permissions
or...
delete ntuser.dat in your profile, windows will recreate it or if you dont want to take the risk then...
Search for ntuser.man & rename it to ntuser.dat if you don't pick up ntuser.man, then logg in with safe mode & networking as administrator, rename the corrupt profile, then, logg in again as yourself so that a new profile is created.
Jun 04, 2008 | Sony VAIO VGC-RA820G (027242657700) PC...
HP dv1000 start up and Workgroups visibility problems
I have heard of IE7 causing some problems with resource hogging - if you don't absolutely need it, the best thing to try is to uninstall IE7 and see if that fixes the problem. If it doesn't, leave another comment on this ticket and we can try something else.
May 26, 2008 | HP Pavilion dv1000 Notebook
AUDIO DRIVERS
If your drivers are from trusted source just click ok continue when the windows signing for drivers pop up window appear.
Now if you click ok and then the system fails to load and then give you a blue error screen, its caused by either
  1. The hardware or its drivers cause conkflict to the system, because your drivers are not from a source you can trust and they are not in compliance with windows OS features and as a result can not run in a windows OS. So get a fresh copy of the drivers from a trusted source preferably the product manufacturer
  2. The hardware itself is faulty and on installing to XP it causes a conflict in which case you can try the Sound card on a different PC and see if it runs, otherwise you need to replace it.
  3. (Assuming XP has finished loading the OS) Sometimes XP fails to unistall the previous drivers, if this is that case goto the device manager (windows icon >right click > properties >hardware > device manager) select ypur current sound card unistall the driver that is there and then restart your machine and load the new drivers again
Mar 25, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
HP Pavilion dv1000 Notebook Logo
648 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
