Question about Xerox 8825 Copier
How would I correct a LL - 22 error code? - Xerox 8825 Copier
    New Friend:
  • 51 Answers
Clean or replace transferand detack coroton wires
Posted on Dec 12, 2010
What is f-22
F22 means you have a door lock problem you need to unlock your door to correct the problem
May 22, 2014 | Whirlpool WFC7500VW Washer
Error code 22
"Error 22" on a Pioneer usually means an unsupported CD format. The disc you are trying to play is not supported or is very badly scratched so the player cannot determine the format.
Dec 19, 2013 | Pioneer Car Audio & Video
Error code p0077 p/d
Hi there:
P0077 - Intake Valve Control Solenoid Circuit High (Bank 1)
Check in this link page 22: FSM//H4SO%20Engine/GD(H4SO)%20General%20Desc.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 20, 2012 | 2006 Kia Rio
Dr is flashing. The error code is E41. How do I correct the error code. Door is closed. Started flashing in the middle of cycle.
Hello, welcome to FixYa. I understand you have a Frigidaire washer with an error code E41, correct ? Can you reply and include the complete model number ? This will let me speak specifically about your washer instead of generalizing...which can be fine, but specifics are always better. I'll watch for your reply and go from there. Thank you. Regards, Macmarkus :)
Sep 17, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a ..tvr608 hi 8 camera..the code c:31:22..i tried removing tape and letting sit open for 24 hrs to dry (per manual) nothing..any suggestions??seems like " tape drive " is slipping..if...
Hi
Thanks for using FixYa. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whacking the camera sideways, if after doing this still the issue is not resolved then you’ll have to get the Gear assembly replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 13, 2010 | Sony Video Cameras
How do you fix Status Code LL-22
‘LL-22’: High Voltage Transfer failure. I would suggest calling your local Xerox tech.
Jun 24, 2010 | Xerox 8830 Copier
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Computers & Internet
213 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
