Question about Epson TM-T88III (C420863)
Greetings! I have a TM-T88iii - parallel connection version. Connected to Win XP Sp3 computer, through an ad on multiport Startech card (parall 2 serial ports) As I check printer ports connections choice in printer properties, I see LP3 and ESDPRT001 - which also seems to be a parall port. Might have been installed by TM-T88iii? First i leave the printer connected to LP3 - RESULTS: 1. we have a commercial money wiring program (akin to WesternUnion) installed. Epson printer prints receipts OK 2. trying to print off Win program (Notepad) OR printer's own "Test Page": result - "Page failed top print - ... - State of the printer is invalid" THEN I CONNECT the Epson printer to ESDPRT001 port. RESULTS: 1. Money wiring program does not print receipts 2. Win (Notepad) prom and Printer's Test Page send docs to spooler where that stay withjout ptinting. LAST, while docs are in the spooler (see above 2.) - I switch the printer to LP3. RESULT: docs in spooler now print. Will appreciate any input. I have reinstalled adon I/O parall/serial card. Thanks
SOURCE: Connecting Epson TM U220D printer with Laptop (having Windows XP)
If you have the Cables2GO USB to Parallel converter, it is a pain to get working.  Go to Radio Shack and buy the GigaWire USB to Parallel.
Then once plugged in, go the printer that will be using the converter.  Go to the printer properties, select the PORTS tab.  Select the 'VIRTUAL PRINTER PORT FOR USB'.  That worked for me!
Posted on Nov 12, 2008
SOURCE: Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Posted on Dec 13, 2009
  • 3 Answers
SOURCE: Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Posted on Feb 18, 2010
bmrdude
  • 52 Answers
SOURCE: I have reinstalled an Epson
The cash drawer is loking for a signal from the printer to fire the drawer. It is usually on one of the pins of the cable comming from the printer. You will probably have to contact the cash drawer manufacture for that information.
You can contact Southeast Digital Networks, Inc. for more info.
Tel 850-681-9528
Hours of operation Mon - Fri 8:00am - 5:00pm EST
Posted on Mar 07, 2011
bet3
  • 105 Answers
SOURCE: I have a retail store with 7 x Win 7 Workstations.
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Posted on Apr 12, 2011
XP won't boot with Startech Video Splitter
try to reinstall your Win xp and if it is the same check other system that work for there model and make they may not be compatible
Apr 18, 2012 | StarTech.com Ltd. 2-Port VGA Video...
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Apr 12, 2011 | Epson TM-T88III Thermal Printer
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
Tm t88iv print slow
This is definitly a driver problem. Change the driver to one that is compatible with Win XP.
Jun 03, 2009 | Epson TM-T88III Printer
EPSON TM-T88iii printer 'Not Available'
I've had this issue many times. The only resolution is to completely uninstall the printer using the epson utility then re-install. This solution is only temporary as it will go to unavailable within 2 or 3 days.
Apr 09, 2009 | Epson TM-T88III Thermal Printer
Can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III - Always showing as not avaliable
I had the same with XP .... I had my home inkjet (Parallel port) on LPT1. The Epson TM software and printer worked fine after removing the ink jet from LPT1 and re-installing the TM driver.
May 08, 2008 | Epson TM-T88III Thermal Printer
VeriFone Tranz 330 Printer Cable to Epson TM-T88iii Printer
Absolutely not. The Tranz 330 port is an RS232 serial port.
Mar 12, 2008 | Televison & Video
Epson TM-T88III (C420863) Logo
934 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
