Question about GE Refrigerators
NOT GETTING COLD-COMPRESSOR SEEMS INOP - GE Refrigerators
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
Why has my freezer stopped cooling ?
The freezer does not get cold the evaporator fan motor might have stopped working.
http://thesisreviewadvisor.com
Jan 08, 2015 | Refrigerators
We have a Kenmore side by side model 52584201. Yesterday the freezer side stopped working. The refrigerator still cools. I have checked all the vents and cleaned around the vent at the bottom. Any ideas,...
FREEZER IS WHERE THE FRIG GET'S COLD AIR. IF BY NOW YOU HAVE FOUND THAT THE FRIG IS INOPERATIVE. CHECK THE OVERLOAD RELAY ON COMPRESSOR. HAD TO REPLACE ONE ON MINE PART WAS ABOUT $60
Feb 26, 2010 | Kenmore 52582 / 52584
Display says hi temperature, wont change when i adjust it. Tried turning it off/on and putting it on factory defaults. Also, air filter change light is on, and water wasn't coming out for a while until i...
Check underneath the refrigerator to see if the coils are clean. If they are covered with gunk, clean them.
Next, check the operation of the compressor (close to the coils mentioned above) and the compressor fan (also near the coils toward the rear of the refrigerator). Both of these must run for the unit to have the proper level of cooling. If the compressor fan is not turning, you will need to replace the fan motor.
Another possibility would be an inoperative evaporator fan inside the freezer unit. However, when this fails, the freezer often remains adequately cold at the top. The refrigerator part does not get cold enough.
Oct 19, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
A/C inop
The compressor is brought in by a magnetic clutch, check the voltage at the clutch. If you get 12 volts at the clutch, then the magnetic clutch unit may be bad. Also if it has leaked out the gas, there may be a pressure valve that is designed to prevent the clutch from engaging
May 01, 2009 | Heating & Cooling
Running fine but blowing warm air
"it seems to work fine but will not get cold"
Not sure how it can work fine and is not cold. When you say work fine, is the light on and the freezer fan blowing but is the compressor running?
Unplug the Ref and wait about 30 min or so, plug it back in and listen for the compressor to start running. You should be behind the Ref to hear this. If you don't hear it start running then you may hear a clicking noise. This clicking is a problen with the compressor start relay. If the compressor runs but still is not cold then it could be low on coolant.
Dec 16, 2008 | Refrigerators
Ac not working
It sounds like the air temp control bleed door motor is inop, I think it is electric in your year and model.
Aug 02, 2008 | 2004 Dodge Intrepid
Freezer inop; water dispenser inop
Refrig. cant work unless the freezer is working ...all cold in produced in freezer and circulated to refrig. check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 26, 2007 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
