Question about Whirlpool LHW0050PQ Front Load Washer
It quit in the middle of the cycle with a code f 21
    President:
  • 1,932 Answers
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank You
Posted on Sep 06, 2010
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
Jan 24, 2012 | Honda Electrical Supplies
The f 21 code comes on and we have checked the hose and the drain to the house. I don't know who to check the washer itself but can drain with a shop vac. after you drain the s5 code comes back on when you...
There are 3 screws at the bottom of the cabinet, remove the bottom panel. There is a screwtop cylinder right in the middle. Unscrew it. Problem solved! Give me a rating if I am right. Good luck. Make sure you have a towel!
Aug 22, 2010 | Kenmore HE2 Plus Front Load Washer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
Oven cleaning mode quit in middle of cycle. unit
prob blew the high limit thermostat in the rear of the unit, pull unit out remove back panel and check that thermostat for continutiy with a meter.. hope this helps
Feb 05, 2010 | KitchenAid Kitchen Ranges
Code error for O2 sensor?
Code 21 the check engine light will flash 21 times cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
Aug 29, 2009 | 1995 Dodge Neon
Will not go into spin cycle
machine just quit while washing the code F-21 showed up
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Fault code f21
There is a clog in your hose. It happened to me, same washer. I took the hose off and blew into it, the clog came out.
Dec 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
