Question about Toshiba TDP-S20U Multimedia Projector
What is the part number for the ballast in the toshiba tdp-s20 projector?
SOURCE: Toshiba TDP S8
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
Posted on Dec 30, 2007
  • 9 Answers
SOURCE: Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Posted on Jan 22, 2008
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: The color went out on my Toshiba TDP-T45
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Posted on Jun 24, 2009
  • 23 Answers
SOURCE: Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Posted on Jan 21, 2010
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
Jan 05, 2010 | Toshiba TDP P4 Multimedia Projector
Due to voltage fluctuation fumes come out from the projector what might have happened? and what would be the repairing cost?
you fried the power supply board and/or the ballast. you'll spend more on the labor than the part itself, and toshiba won't sell the parts. you'll have to send it in to them.
Nov 11, 2009 | Toshiba TDP-MT200 Multimedia Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
TD9-S81 no power when data projector comes on
no leds? bad power supply. leds but no fans? bad button panel or main board. led and fans but no light? colorwheel or ballast.
Sep 18, 2009 | Toshiba TDP-S81U DLP Projector with...
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Request for the help with Tosiba S20
looks like you are having a ballast issue
projector needs to be serviced
May 14, 2008 | Toshiba TDP-S20U Multimedia Projector
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
Faulty projector
You will have to give a Make and Model of your Projector.
Could either be your lamp that needs replacement or a faulty Ballast ( lamp's powersupply )
Nov 09, 2007 | Toshiba TDP-T45U DLP Projector
Toshiba TDP-S20U Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
