Question about Poulan Pro Chain Saw 46cc 20"
Saw cut is not straight. It curves until it freezes the chain.
  • 487 Answers
Hi, sounds like the blades on the chain are either blunt and need sharpening, or they have been sharpened at the wrong angle.
Hope this helps
Posted on Sep 06, 2010
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain saw cuts through a log in a curve, and then will not cut. Depth gauges are correct and chain is sharp. Will plunge cut and cuts small logs, but will not go through a big log. What might be...
Cutting in a curve is either the cutters are longer on one side than the other, or the bar rails are badly worn, more so on one side.
Jul 12, 2011 | Garden
Saw cut is not straight. It curves until the chain freezes. Model 330 type #1 Chain saw.
This problem is caused by sharpening the chain on one side more than the other or can be caused by having the angle wrong when sharpening one side which causes one side to cut better than the other. The only solution is to get it sharpened professionally. All chainsaw users have to do this every few times we sharpen them.
Sep 06, 2010 | Sport & Outdoor - Others
It's like cutting with a butter knife - not really chipping the wood, but rubbing it, very dryly- changed the chain out and still same problem. Chain is on in correct direction. Cleaned out oil/lubricant...
Check for side play of the chain in the groove in the bar. If the chain can tip it leads to poor performance and cutting in a curved path, not a straight cut since the chain can wander. Also consider a more agressive chain since the standard "consumer" chain is designed to be extremely safe with a large raker which limits the depth which the chain can cut. Here is a good article on saw maintenance:
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Bob
Apr 19, 2010 | Garden
20" poulan chain saw cuts at angle
Hi
You must have hit a nail or stone with the one side of the chain. When the chain gets duller on one side than the other is what makes a saw cut at a angle. Get the chain sharpened and it should cut straight again.
Sam
Jan 08, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw cuts great at start, not so good about 1/2 way
All things are possible but it isn't likely the bar is bent. Are you getting fairly large chips or sawdust? Try raising the rear of the saw a little when she quits cutting. so you have a small contact area instead of a wide flat cut. Run a flat file at an angle along both edges of the bar to remove any wire edge. Let me know what you find you have piqued my curiosity. Lou
Oct 01, 2009 | Garden
I have a husqvarna 350 chainsaw, it wont cut straight throuh a log without cutting at an angle and getting jamed. what is the problem , any sharpening tips
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Sep 17, 2009 | Husqvarna Garden
When cutting, as it progresses, the cut curves to the rught automatically.
Sharpening a chainsaw is an art. I wokred in the logging industry for 20 years before I was shown how to truly sharpen one well!
It appears that your problem has one of two causes.
1. Sorry, but you may not have filed the chain correctly, a common problem for newbies and some veterans. Ensure that all cutters are filed at the same angle (save your old chain and buy a new one for a quick solution). The file should be worked from the back of the tooth to the point ONLY. The file should be stroked at 90 degrees to the bar and parallel to the line that is inscribed on the tooth (if a line does in fact exist). Each raker should also be the same height - get a raker gauge from your chainsaw shop. If the rakers on one side of the chain are lower than the other side and/or the cutters are filed at significantly different angles on one side than the other the saw will cut in a curve.
If you look at the cutter from the side each one will show a quarter moon filing "circle" and both sides of the chain MUST be equal or close to equal. If one side has a moon and the other does not the saw will cut in a curve so severly it will bind in the cut.
2. A worn bar that is higher on one side of the chain groove than the other will also cause problems - a new bar is the only long term solution for this. The unequal height is caused by incorrect filing of the chain and long term use of the bar with this condition.
If the bar is in good condition and the rakers and cutters are filed properly you will not have to push on the saw to make it cut - it will pull itself through the wood. Indeed, before you buy a bigger saw to cut faster you should ensure correct filing - you may amaze yourself and your buddies!
I am a Certified Faller in the Province of British Columbia, Canada if you are wondering about my credentials.
Good Luck and Safe Cutting!
Doug Hough
Parson, B.C.
Jan 18, 2009 | Husqvarna Chain Saw 20" Bar
Chain saw cuts at an angle
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Jan 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Nov 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
152 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
