Question about Amana AFD2535DES French Door Refrigerator
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
  • 944 Answers
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
On a 207 G6 GT Pontiac retractable hardtop where is the sensor that gives the message top not secure. Top goes up and down seem secure will not allow the trunk to open with the key or door button
The retractable hard top is controlled by the folding top control (FTC) module.
The folding top control (FTC) module
Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
May 29, 2015 | 2007 Pontiac G6 GT
TRAY UNDER DOOR DOESNT OPEN AND SHUT PROPERLY MODELCCP-509
One of the tabs on the bottom of the drop panel (the lower metal door that folds out) is bent incorrectly. Try bending it a little which every direction is needed to close the drop panel.
Do not break it, there are no replacement parts for that brand.
Nov 07, 2013 | Helman Group CCP509 Popcorn Maker
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
How do you put the top down on a 1966mustang? It's a manual top... I think.
Down
- undo zipper on one side about 12" just to take a little tension out
- undo latches
- top down 2"
- close latches (if you do not close them you are going to rip your top)
- top down all the way, if you see a little circle and it is not folding just right, stop mid way and give it a light karate chop movement to help it fold properly
*put the boot on for long drives, it will protect the top
*store the car with the top up, it keep the material nice and properly stretched
Up
- Windows down at least 75%
- Top up and when it gets about 2" from being closed stop and open latches
- Close rest of way, match up the pins and give it a little pull and snap the latches
Feb 24, 2011 | 1966 Ford Mustang
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
Op code with the lid closed
Greg,
You have lost signaling thru the Left Hand Lid Lock.
See this link for OD troubleshooting. If you have questions post back and I will help you….Rich
Some handy links for your machine FAV6800A or FAV9800A correct?
The Service Manual for reference. Sears Parts Direct for reference.
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Frozen refer door prevents water from dispensing
fold the door gasket back remove screws on side,,, top... bottom ..put more insulation on hose keep it on the front side away from freezer and put it back together....make screws just snug until all are in(you may need to adjust door to close...when door will close proper tighten screws all the way
Aug 19, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
Amana AFD2535DES French Door Refrigerator Logo
216 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
