Question about Altec Lansing iMT525
It paired fine with my old iphone 3g but since i have my new iphone 4 it wont pair. the circle spins on the phone....its sees the sound blade but it wont pull up the ability for me to pair it. does the old imt525 not pair with the new iphone 4? and if you need to know i have a mac not windows. lanny donoho
    Brigadier General:
  • 3,917 Answers
Hi
The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual.
Please check this link for the manual:-
http://safemanuals.com/user-guide-instructions-owner-manual/ALTEC%20LANSING/INMOTION%20IMT525-_E
Also check this link:-
http://www.askdavetaylor.com/how_can_i_pair_connect_bluetooth_speakers_mac_macbook.html
http://cnettv.cnet.com/how-connect-your-ipad-iphone-bluetooth-speakers/9742-1_53-50090652.html
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 06, 2010
Can not connect bluetooth to MY65T Navman
I've got MY65T working on an iPhone 3GS. I previously had the problem where it would pair and retrieve phone book, but not transmit or receive voice from my iPhone when making a call.
The last thing I did that fixed it was to remove the bluetooth pairings and "reinstall software on your navman". I don't know if this may remove some of your settings / POI / etc. This was a new purchase so I didn't have anything to lose.
Before doing this I had upgraded the navdesk software to 7.30, and installed the latest firmware for MY65T. Firmware is located at http://www.navmansupport.com.au/Software/My%20Series/MY65T/MY250___352.htm
Details:
-remove the phone bluetooth pairing from the Navman from Settings / Bluetooth / My Paired Devices / [your phone] / delete
-remove the bluetooth pairing from your phone's settings
-connect navman to PC and launch navdesk
-click "My Navman" / "Reinstall software on your Navman"
-download the install file if prompted
-accept the reinstallation prompts and complete reinstallation
-set your phone to discoverable over bluetooth (just keep it on the Bluetooth settings screen on iPhone)
-go to Settings / Bluetooth /" Search new devices" on your Navman
-click your phone's name on the navman's discovered devices
-enter the PIN onto your phone when prompted and accept the pairing. This takes a little while.
-test handsfree!
Nov 29, 2010 | Apple iPhone 3G
When i try to turn on the bluetooth function on my 3gs it remains in the search mode- (the circle of death) forever and doesnt pair with my motorola H710! Help!!
it wont pair whatever you do. even if you install a photoshare app on your iphone, it still wont be able to transfer files to and from your iphone. the iphone's bluetooth only works with other iphones/ipod touch.
Aug 03, 2010 | Apple iPhone 3G
My new iphone 3G wont pair with Tom Tom 520 - the tom tom finds the iphone, the iphone seems to find the tom tom, but iphone will not make full connection Any ideas please
i dont think the iphone will pair with the tom tom gps, because they use a different satellite & interface....iphone is running on Google whereas tom tom has its own satellite.
Mar 10, 2010 | Apple iPhone 3G
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
Oct 27, 2009 | Apple iPhone 3G
My iPhone 3g with navman s50
You will need to update your navman firmware
If it is a old model gps check the navman site for compatability.
Aug 04, 2009 | Apple iPhone 3G
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
Multipoint bluetooth wont work with iphone 3g
I actually have both products, and I was able to get my bluetooth to work with 2 phones. All you have to do is first pair your phone with the H721. Then in the phones functions, turn off the bluetooth so it is no longer in discovery or connected...but do not turn off the bluetooth itself, just in the phones settings. Then go to the bluetooth settings in the iphone. you should see the H721 in discovery but not connected. Before connecting it you must put the H721 into discovery mode as well. Hold all three buttons down for 19 sec. it will go solid blue. then push connect on your iphone. onces connected, go to the original phone and turn the setting back on for bluetooth connection. both are now connected. Only one may apear to be connected, but both are. test it with another phone. call each number and you will see that you can now answer both calls with one device. If the iphone is connected and phone 1 rings...the H721 disconnects temporarily from the iphone and connects to the other device to answer it. Hope this helps. Cause thats how I got mine to work.
Oct 27, 2008 | Cell Phones
Altec Lansing iMT525 Logo
481 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
