Question about Samsung HT-TX72 Theater System
Smoke rolled out and then the unit shut itself down
    President:
  • 547 Answers
By and large, electronic devices need the smoke to stay in for them to work. Once the smoke comes out, they generally don't work anymore.
Joking aside, the only parts that can generate enough heat to produce smoke will be the power supply transformer and capacitors. If you're lucky, the damage will be limited to the power supply, but there's a good chance that it went unregulated while it was failing and so dumped 120V into the main circuit board and cooked other components there.
If you are up for soldering, then open the unit up and post details of what components have visible damage, as well as detailed info about the circuit board revisions.
If you're not, then it's probably time to shop for a new receiver.
Posted on Sep 06, 2010
My dyna glo rmc-kfa120 firesand shuts off 3-4 times and then quits. smoke rolls out front. any ideas.
The exhaust is probably clogged and needs to be cleared out. Please shut down the unit completely before servicing.
Feb 03, 2017 | Heating & Cooling
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Blue Smoke .... Faulty PCV ???
does the engine idle smoothly? is the service engine soon light on? the engine is running rich causing the blue smoke.it could be pcv valve but unlikely
May 23, 2012 | 2002 Ford Explorer
Program shuts down during exercise. Resets to default program. As if rebooted. have all new parts,(alternator, key board, gray cable, resistor, power input )
I am having the same issue with my 4XXX StairMaster unit.
I am suspecting that the voltage regulator on the lower board is at fault and that a lower board replacement is in order. I have checked everything else (motor, resistor, power supply).
Try this:
My machine REBOOTS if I choose:
- Rolling Hills
- 200 lbs
- Difficulty 20
- 20 minutes
My machine OPERATES NORMALLY when I choose:
- Rolling Hills
- 200 lbs
- Difficulty 1
- 20 minutes
Apparently, the problem only manifests itself at HIGH RPM, which is probably related to a LOWER BOARD / VOLTAGE REGULATOR issue.
Graham Leach
Apr 12, 2011 | Stairmaster 4400 PT Stair Stepper
My heater is brand new and worked for 3 days. i have no heat, i also have 4 flashes blink code. indicates high limit/ rollout switch. i have rechecked the thermastat, gas line and the vent pipe, the fan...
There is something else that is causing the Overload/Roll Over Switch to trip. You can try unplugging the unit from it's electrical source and wait 30 minutes before plugging it back in. That may allow it to reset itself. Unfortunately the Overload/Roll Over Switch is preset at the factory and is not adjustable.
If the unit resets itself and starts working again, but then shuts down, check your Owners Manual for other causes. If you've misplaced your Owners Manual, here's a link to it, that you can download and print.
http://www.heaterstore.com/images_templ/mr-heater-heaters-mhu45-75lp-ng.pdf
Hope this helps to get you headed in the right direction. If all else fails, call the Technical Service Dept at the number listed in the Owners Manual.
Mar 03, 2011 | Mr. Heater MHU75NG
Starts runs for a minute two the shuts down and blowes smoke
jerome kr406,
This is a classic problem with the reddy heaters. They have a filter which over time plugs up. This causes the air/fuel mixture ratio to change because the pump pressure is determined by the air bleed. As the filter plugs the air pressure drops and the fuel also drops meaning the burner is running lean. This eventually causes the unit to shut down and as you said smoke comes out. It is a fairly easy fix and I have a tip which will walk you through it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters . My tip will link you to the place to get the parts you need as well as how to perform the additional maintenance that these heaters require.
Thanks for using FixYa and for the excellent rating. Great ratings help to keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
My car is 1999 pontiac grand prix. when I start it smoke is coming out of the exhaust and the car is making a funny noise. it smells like gas and then after a few minutes it turns off by itself. what could...
sounds like ur emision sensor is telling the ecu=electronic controll unit to shut down as your vechicle sounds like it is running on a rich air/fuel ratio
Oct 22, 2010 | 1996 Cadillac Seville CA Value
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Samsung HT-TX72 Theater System Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
