Question about Samsung PCN5425R 54" Rear Projection Television
No picture I have sound, but no picture. The picture took about five minutes before it would appear, then was very fuzzy, then would come into focus as normal. Now the picture is blank. But I am getting sound. TV was functioning normally before this problem.
  • Twiggy Moonshoes
    Twiggy Moonshoes May 13, 2008
    the sticker with the model number is torn.
    The last four numbers are 5415R. Samsung website is showing either POM or PCL
    The red light blinks for about ten seconds and then goes out. It use to blink and then the set would come on. Now it blinks and then nothing.
    But the sound does work.
    I am only running a dvd player. No broadcast or cable connections. If the dvd player was not connected the screen would be blue. Now, nothing. Just blank, as if it is off. When I press the power button you can hear the power "relay" come on. And when you turn it off the same thing. You can hear the "relay"
  • Twiggy Moonshoes
    Twiggy Moonshoes May 14, 2008
    I have already tried the unplug trick.
    After several "jolts" which I tried before,
    no luck. You say lamp replacement? How many lamps are there? I what looks like three.
    By the way the model is PCL5415R.
    thanks
    Genius:
  • 1,447 Answers
Whats the exact model? are you getting a red light on the led lights on the on button? flashing or solid red? check all the connection make sure all are tightly connected from the back of your television
Posted on May 13, 2008
  • 1 more comment
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 13, 2008
    First, try the unplug it, wait a few minutes, plug it in trick, several
    times. If that doesn't work try pressing the power button and slap the
    back left side of the set several times. Sometimes, this will shock the
    ballast and/or lamp into working. If still no luck, check the manual
    for instructions on lamp replacement and unplug, then, reseat the lamp.
    Edgar Allan Pagayona May 15, 2008
    did you hear a pop before this issue occurred, because you might need to replace the bulb for your tv
    here the link for the parts
    samsung parts
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Photos are fuzzy
as you take a picture ( scene w/o flash ) slightly press the snap button and wait till red or green box appear, if red box, out of focus. if green box in focus. when green box, make sure you and the focus are very still, then take a clear picture, pressing the button all the way. make sure no shaking as press button either.
Mar 17, 2010 | Samsung S760 Digital Camera
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
All of the pictures taken are very fuzzy no matter what you do
check to see if a flower appears on the screen. If it does then the camera is set to macro and all your pictures except close up will be fuzzy. To switch macro off, move the ring on the front of the camera till the arrow is pointed straight down. I was having the same problem. Wasted a whole day of vacation pictures. That was what fixed my problem and I hope it fixes yours too,
Feb 17, 2009 | Samsung Digimax A503 Digital Camera
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is fuzzy, focus & screen fuzzy even before picture taken
sounds like its a physically damaged screen, if its still under warranty take it back to the store, if not im sorry to it's gonna be a chuck it away and start again job.
Sep 29, 2008 | Cameras
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Horizontal fuzzy purple images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 21, 2008 | Canon PowerShot A95 Digital Camera
Fuzzy pictures
Go back to film. Digital SUCKS.
Dec 21, 2007 | Casio Exilim EX-Z50 Digital Camera
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
