Question about Compaq Presario M2000 Notebook
Does not power on
With or without power adaptor she does not power on
  • Tazman1942 May 18, 2008
    I have the same problem, and I think the cause was an overheated AC power supply. I have gone through checking the power circuit through the jack right to the motherboard. I beleive the problem to be a diode right after the connector has gone bad. I checked continuity through the diode and the values are as high as another diode of the same type was checked. I have heard there is a problem with this componet failure on the M2000 board. Has anyone else heard this?
    Tazman1942
  • brodgers Oct 15, 2008
    I have the same problem. I was doing some work on my laptop and it just shutoff. Now I can't get it to do anything whether its plugged to AC power or on battery. I have purchased two power adapters for this laptop in the past 3 years, the last just a few months ago. I'm not sure if the laptop has been ruining the adapters or if the adapters have cause a problem with the system board. The adapters are of the correct specs for the unit
The PC will not power by battery or AC adapter.
Note: As of yesterday I have purchaced another motherboard. After close examination I found a hair line crack on the underside of the motherboard where the DC jack is affixed.
Thank you all for your responses.
Posted on May 21, 2008
  • 37 Answers
First try removing the battery.
Try to power on again, if not mail me.
Erik.
Posted on May 16, 2008
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Fujitsu SIEMENS LIFEBOOK not starting no power in
Check the power adaptor to see if the power is coming out, as well as there is mains power going into it. The laptop should operate without the battery, if the power adaptor works.
Oct 11, 2014 | Computers & Internet
Lights dimming
Ussally this is caused by a bad connection to the power adaptor a good way to find out is if it does it without the power adaptor while using just the battery
Oct 13, 2013 | Acer Computers & Internet
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
My laptop screeen light seems dim without electricity
When you disconnect the power cord, the power settings change. Check the power settings for your screen backlight in Control-Panel-Power Settings.
Oct 14, 2009 | Samsung NC10-14GW PC Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
D1-524 without power
this unit use an adapter rated at DC 5V 2.0A
the connector is the issue as long as it matches the above specs and the connector will fit.
take the dc adapter to any radio shack and have it tested.
Jan 26, 2008 | D-Link AirPlus DI-524 Wireless Router
No power adaptor
Look to see what voltage, amperage, polarity and try to look it up in www.ebay.com
Sep 06, 2007 | Lexmark Color JetPrinter 3200 InkJet
No power
Measuring the voltage outputs without applying a load doesn?t eliminate the adaptor as the problem. You also have to know how may amps it can supply as well. To answer you specific question common problems are defective battery, A/C power supply and my favorite?s defective power connector or circuitry inside. When you plug in the A/C power adaptor do any of the LEDs light, up? Does anything happen? Also try removing the battery, plugging in the A/C adaptor and try powering up. If this doesn?t work please supply answers to the above questions plus any other pertinent information you may have. As always please don?t forget to rate the posting but please wait till after we?ve finished.
Jan 16, 2007 | Dell Inspiron 500m Notebook
Compaq Presario M2000 Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
