Question about Refrigerators
I have a whirlpool side by side refrigerator (model # ED25TW) and my icemaker has a number of ( IM#S 106 626636). My problem is that the water is overfilling the ice tray. My question is can I adjust the length of time the valve is supplied voltage. It appears that the icemaker has two adjustment screws located in the front panel (one in front, and one on the side of unit). please advise if one of these control the time length of voltage to the inlet valve. If so, which one and what direction (clockwise or counterclockwise) to decrease the time of voltage to the valve. Thank you Gary French
  • 184 Answers
SOURCE: Ice maker # S10626636 water level adjustment
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Posted on Mar 27, 2008
  • 1122 Answers
SOURCE: Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Posted on Oct 17, 2008
  • 9 Answers
SOURCE: ice maker seems to be overflowing with water
check for a ice blockage inside that fill tube that sits in the ice maker.
Posted on Jan 10, 2009
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
Icemaker overflows problem is worse when arm is in off position
All you need to do is turn water off until someone can replace the dual water control valve found on floor and back side of your refrigerator. You are going to need your model number so you can find the correct parts. Most Whirlpool Refrigerator model numbers are found inside the fresh food compartment and around the door. Whirlpool refrigerators made in the U. S. will find the parts manuals by going here=> User Manuals
A pace to find parts is by entering your model number=> HERE am not sure why many places have the dual water control valve with the photo of your ice maker. If you have questions I will be here so please ask. Thank You Sea Breeze
Feb 15, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 6 year old side by side Whirlpool Refrigerator and the ice maker stopped working. It is still getting water and there is no ice jammed. Any ideas on what to do?
u need a new im module on the front of the icemaker,,,,,,,,, It could be ur water valve possibly but u say ur gettin water so prob not... the module is all u need but it is also included on a new im maker if u were to buy one but its not necesssary.. there about the same price go figure ....... u will need whirlpool part number W10190935.... go to repairclinic.com to see a picture of it ,,, all u do is remove the whitr cover piece that just snaps over the end of the im unscrew it and install the new one... good luck
Jan 31, 2010 | Whirlpool Refrigerators
No water flow to icemaker
First verify the fill tube feeding the IM is not frozen with ice. Then verify the water valve is working and power is applied when the IM cycles, It will be one of these things.
Eric
Oct 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICEMAKER ON WHIRLPOOL ED2GHGXMQ
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 14, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model ED25TW intermittent freezing
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Oct 15, 2008 | Whirlpool Refrigerators
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Icemaker not working
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
