Question about Jensen MCC-8525 Cassette Player
I have a Jensen MCC 8525 marine radio, pushed the wb button, and now cannot get the radio to play anything other than the weather band. What is the trick with this radio?
  • Tom Sheahan
    Tom Sheahan Apr 28, 2014
    I did the same thing. Did you find a solution?
4 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
Posted on May 19, 2008
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
Posted on Jun 25, 2008
SOURCE: Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Posted on Jan 01, 2009
Clarion radio from 2002 Saab 9-3 Viggen. Radio works fine on AM,FM,and CD, but the Weather Band does not switch the display nor receive WB broadcasts. (Radio has Onstar module, but that service is dying,...
it i.s apparent that either the button to ingage the wb is not making contact with the module inside or there is a fault on the main board inside the deck. now depending on how old the deck is I would most likely suggest you either have it repaired at an car audio shop or just replace it with a similar unit.. please rate this...thanks
Sep 28, 2008 | Clarion Car Audio & Video
Tip
USING THE WEATHER BAND STATION 1. FOR WEATHER STATIONS, CLICK THE WEAIHER...
1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO “WB”.
2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
How do i program my eton fr 800 radio to come on automatically. Thank you.
  • To get your alert radio to come on when there is a weather alert first you needed to find the right NOAH frequency to turn on automatically to.
  1. Extend the antenna fully.
  2. Turn on the radio.
  3. .Press the "WB" button at the top of the radio.
  4. Turn up the volume and press the ^ or v button to cycle through all 7 of the weather channels.
  5. WB and CH will appear at the top of the display., with 1-7 next to CH.
  6. Select the strongest channel you can hear (if you can hear more than one channel. Usually only one channel is heard).
  7. The strongest one is the broadcast from your area.
  8. Now adjust the volume you want the radio to turn on in the event of an emergency.
  • Now once you have the weather frequency set for the radio to turn on to, we need to make it able come turn on in an emergency.
  1. Press the ALERT/WB button at the top of the radio.
  2. The alert light shines in the upper left corner of the radio.
  3. The audio will disappear but the radio is still on.
  4. It will monitor Noah until an emergency occurs and at that point a siren or a voice will alert you. Then you press the WB button to hear the alert.
Regards, Tony
Apr 27, 2011 | Audio Players & Recorders
My uniden pc68ltw seems like it wont switch from weather band to cb. I can still hear the weather band after i switch to cb. I can not hear anyone one cb mode
You need to take off cover locate wires to that switch and cut them loose from CB/WB and buy a Toggle switch to mount outside radio and switch it on/off like to make CB/WB selection..Seems that switch inside is screwed. needs new one. I would rigg it myself. By drilling hole in cover and placing outside toggle with white marker saying Cb top Wb bottom.
Mar 23, 2011 | Midland 75-785 Handheld CB Radio
Cobra marine band radio will not transmit more than a quarter mile is it blown?
Before changing out the radio try the radio on a ANTENNA RADIO TESTER or try it on a different antenna. Good luck.
Jan 05, 2011 | Cobra Marine Vhf Radio
How do you set the clock on a Clarion MO350 marine radio/casette player? Rick
After spending an hour, here is how you do it. With the radio playing, press and hold the BAND button, until the word MANUAL displays in the bottom left. Then press and hold BAND, plus DISP (4). The radio will then go into Clock mode. You can change the hours by pressing the left scan, and the minutes by pressing the right scan. When finished, press the BAND button. To exit MANUAL mode, press and hold the BAND button.
Jul 03, 2010 | Car Audio & Video
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
Manual
What you want to do is set your radio to the proper S.A.M.E. (Specific Area Message Encoding) code for your county. You will find this information on the NOAA website which can be found at www.weather.gov/nwr/indexnw.htm. Find your state and it will list S.A.M.E. numbers by county.
Setting the code:
1. Push the CNTY/CH button on your radio. 4th button from the top /2nd up from bottom. This will prompt you to set the county.
2. Push the SET button. Button at bottom right. This will prompt the screen to show a set of 6 numbers flashing with the first number.
3. Under the screen you will see a set of 5 numbers and a 5+ with its corresponding button underneath. Use these for setting the code. For numbers above 5 use the 5+ button (e.g. 7 = 5+2). You will be able to set your radio for 10 different S.A.M.E. if needed. To do this you scroll through each S.A.M.E. number by pushing the CNTY/CH button.
4. After you set the S.A.M.E. number, push SET again to prompt you for the proper channel. The channels are A - G. You will want to have your radio on for this to be able to find the clearest channel. Turn your radio on and push the NOAA button under the screen. Push the CNTY/CH button till you get prompted for the SET CHANNEL. Push the SET button and the channel will blink. To scroll through use the TUN- OR TUN+ buttons and find the clearest channel.
You should be all set! Hope this was helpful.
Feb 04, 2007 | Jensen SRWS-1000 AM/FM/Weather Radio
Jensen MCC-8525 Cassette Player Logo
124 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
