Question about Frigidaire FGF366CC Stainless Steel Gas Kitchen Range
Replace the heating element, second time using it turned it on and started to smell gas. Opened the oven and was greeted by a fireball. turned off no damage. I turned it on again and didn't smell a leak coming from the hose. is it not lighting and filling the oven with gas until it finally goes when I open it.
  • Frigidaire Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
m,vn
Posted on Sep 30, 2010
Strong gas smell when oven is on
Bad heating element. Needs to be replaced. Depending on what you plan on replacing it with...call appliance repair shop with you model info and ask for quote to replace heating element.
Feb 10, 2013 | Kitchen Ranges
Takes a long time to get to temperature
If it's a gas oven and has an electric element starter (glows orange to ignite the gas), the element can be taking a long time to heat up, which means the oven doesn't light for a while and so seems to lake a long time warming up. If you turn it on and then look at the area where the flame should be (broiler) and the flame takes a long time this could be the problem. This happened to me and replacing the element fixed it. Now the flames light within 30 second or so.
Nov 11, 2012 | Ovens
I have a kitchenaid gas stove model #KGRT607. The oven does not reach desired temperature and there is a smell of gas when oven is turned on.
I had what seems to be a similar problem with my range, which is a KitchenAid KGRT607HGL6. I'd turn it on, and sometimes it would light, sometimes not. If it didn't light, I'd start smelling gas and I'd have to ventilate the kitchen. If it did light, it took forever to heat up.
That said, I have just finished doing the things I'll describe below, and the oven appears to be operating correctly now. I'm not going to go as far as to say this will work for you, and I'm not even sure which step was the key (maybe it was a combination of everything), but I'll tell you what I did.
PLEASE be careful. Gas isn't something to be messed with. If you have any doubt, you're far better off calling a repairman than blowing the side of your house off, or worse, hurting yourself.
It might help to download this parts list, and refer to page 9, so you know which parts I'm talking about:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208187617.pdf
Here's what I did:
1. Removed the racks from the oven.
2. Removed the pan from the bottom of the oven (it just lifts out).
3. Removed the flame shield by taking out the 4 screws holding it down.
4. Turned on the oven, and saw that the element glowed, but that the gas took forever to ignite. When it did, the flames were weak, shooting out perhaps 1cm from the burner. NOTE: For whatever reason, if I opened and closed the oven door every 30 seconds or so, the oven would start. If I just left the door closed, no such luck. ANOTHER NOTE: If I started to smell gas while I was standing by the oven, I shut off the oven, opened some windows and tried again later. I'm not a fan of emergency rooms.
5. Shut the power off to the oven.
6. Unscrewed the ignitor from the bracket that holds it in place inside the oven at the back.
7. Wiped off the burner element (there was a little buildup, sort of like gray dust).
8. Unscrewed the bracket holding the burner to the oven, allowing the burner to be moved around (can't be entirely removed, just wiggled).
9. Removed the storage drawer from under the oven.
10. Using a hose attachment, vacuumed all around the area where the valve and regulator send gas up into the burner (about center, back under the oven). Look for a brass nut sticking up into the end of the burner tube. With the burner unscrewed from its bracket, you'll be able to lift the burner up a bit and vacuum around it a little better.
11. Reattached the burner and ignitor to the bracket inside the oven.
12. Turned the power back on to the oven.
Then I turned the oven back on, and the ignitor glowed for 30-60 seconds and then the gas kicked on with much more flow than before, (core flame cones about 1.5 cm long with more even flame out beyond the cores) and the oven heated up immediately. I'll replace the flame shield, oven pan and racks when it cools back down.
My guess is that there was something (lint, cobweb, dust bunny, who knows) partially blocking the gas flow into the burner tube.
One other thing I did after the oven seemed to be working was to adjust the air shutter at the base of the burner tube, right where it meets that brass nut under the oven. I got that from Installation Step number 28 (page 6) on the following PDF:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%209755235.pdf
Like I said, I don't know if my solution will work for you. Try it at your own risk, and DON'T DO ANYTHING BUT SHUT OFF THE OVEN IF YOU SMELL GAS. :)
Aug 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
May 23, 2009 | Kitchen Ranges
Build in Over Gas - Oven does not heat
I called a repairman it was the igniter.
Jan 26, 2009 | Magic Chef 9122 Gas Single Oven
Trouble lighting oven, smell gas
Sounds like an igniter problem to me. They are heating elements with a limited life & are quite easy to change. There is one for the broiler on the top as well. Why not try swapping them to confirm this diagnosis. If you never use broil then your problem may be solved!
Dec 23, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Oven element burning without being turned on
no the element, but the thermostat that turns it on, you see the thermostat works like a light switch on the wall for the house lights, it's what turns it on and off.
Dec 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
Replaced oven heating element, now trips electric
Disconnect the new heater and try it again , if it still trips then your problem is elsewhere, if it does not trip, then it points to the new element being faulty.
If it is fan assisted make sure the fan is running o/k.
Hope this helps.
Please leave feedback.
Thanks.
Dec 08, 2008 | Ovens
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Frigidaire FGF366CC Stainless Steel Gas Kitchen Range Logo
179 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
