Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
My GE Bottom Freezer Refrigerator Model:PFS22SBSSS The Refrigerator is not cooling, however the Freezer is mantianing proper temprature at 0 degrees. The temp on the fridge is reading 60 degrees on the inside digital display. I also noticed ever since the fridge portion stopped cooling there's no heat disapating from the top or sides of the fridge like it used to do. Has anyone see this problem?
  • GE Master
  • 5,568 Answers
Your problem is almost surely caused by the failure of the fan that should circulate cooled air from the freezer section to the refrigerator. If you check for vents, normally in the rear of the fridge, and hold your fingers in front of them while you hear the compressor running, you should easily feel cold air coming from them if the fan is running.
To determine whether you want to have it serviced or replace the fan yourself, try entering your model number on the Sears PartsDirect website to see if your unit is one of thousands of non-Sears appliances in their library. If they do, then you will find an illustrated parts drawing with part numbers.
Sears PartsDirect
Posted on Sep 06, 2010
I am assuming its the Temperature Sensor (Thermosit or something like that) and its $10. Someone on here said they got the part for half off and labor was $147. Here in FLorida everything is double.
Posted on Jun 17, 2015
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
GE refrig not cooling. model PFS22SISS
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 21, 2010 | GE PFS22SBSSS Stainless Steel French Door...
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Ice maker spills ice
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
Jun 29, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Hissing sound and constantly running generator
The only thing I can think of that you may be hearing would be if the compressor has a problem. If you notice cooling performance decrease or it stops cooling, I believe you will find the compressor has bad internal valves. It will probably take a technician to properly diagnose this and if the compressor has this problem the only answer is to replace the compressor.
I hope this helps, supertechks
Mar 28, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
312 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
