Question about Walgreens By Homedics Automatic Blood Pressure Monitor 1ea
Blood pressure cure keep reading error and it is never charge even keep the machine charging overnite
    Scholar:
  • 192 Answers
Make sure that the cuf is over your artery, there will be a little plastic point in the cuff to show you where it goes, which is right in the fold of the upper arm from the elbow..... Take care.... Guy
Posted on Sep 09, 2010
When I take my blood pressure the sys number is 21.6 and the dia number is 13.8. How do I convert that to get correct reading?
I have had 3 different testers seeing I have high blood pressure. It seems to me your getting a reading from the wrong area on the machine. Work on batteries or plug in? The battery type must have strong batteries, and not junk batteries. You should get batteries you can charge, and a charger, like I said they need to be strong and that will save you money, and keep them up all the time. It seems your batteries are low already by the reading your giving me. It should say at least 130 and around90 depending on your pressure. Those numbers are not right, there is no converting those numbers, something is wrong, try the batteries. If you don't by a charger buy atleast Panasonic batteries or a good set of batteries, okay, good luck, Frankie!
May 07, 2017 | The Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
What does it mean in the bottom left when it reads 60 then flashes to 01? can't get another reading
The "60" number reading that came onto the screen was your pulse rate. If you can't get the monitor to check your blood pressure again, you may need to replace the batteries, the charge may be too low in them.
Sep 24, 2012 | Mabis ® Automatic Premium Blood Pressure...
The blood pressure monitor reads error 1
make sure you are getting the reader part on the artery just above the bend in the elbow. you may need a new cuff.also make sure it is snuggly plugged into the machine.
Apr 07, 2012 | Mabis ® Automatic Premium Blood Pressure...
I need to know that my blood pressure monitor readings are still accurate. Where can I get my Boots (Omron) blood pressure monitor re collaborated? Thank you.
Generally, the recalibration has to be done by the manufacturer, as the calibration has to be certified. Most manufacturers charge little or nothing for this service. Contact the number in your Owner's Manual concerning how they want you to send it to them.
Hope this helped and thanks for choosing FixYa.
Aug 01, 2011 | Omron Automatic Blood Pressure Monitor w/...
Lumiscope Model 1157 Deluxe Digital Blood Pressure Monitor -- reading consistently high BP, particularly the systolic pressure. Can this be calibrated?
In all most all cases, the manufacturer has to do the recalibration. This is because it has to be certified as correct. Contact the manufacturer for instructions on how to return it. Most charge little or nothing for this service.
Jul 19, 2011 | RTO Vsm Medtech BPM 300 Professional Blood...
I have been getting high readings my doctor readingd are a lot,lower
Blood pressure monitors can frequently become uncalibrated. First make sure that your batteries are fresh since one's running low on a charge can give faulty readings. If this doesn't help, contact the manufacturer, they recommend calling them at 1-800-568-4147 every couple years to arrange for an accuracy test. Page 20 of their manual should help a bit more.
Mar 12, 2011 | Microlife 3MQ1 Blood Pressure Monitor
"Start" Button turns off vital signs monitor
Even if it is plugged in it will not operate correctly without a good battery. When the pump starts to take a blood pressure it draws a lot of power and this forces it to shut off. You should replace the battery and let it charge 12 hours and you should be in business.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jun 12, 2010 | Welch Allyn Spot Vital Signs Monitor with...
How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Apr 10, 2010 | American Diagnostic Corp ADC Advantage...
    WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
    E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
    Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
    Walgreens By Homedics Automatic Blood Pressure Monitor 1ea Logo
    130 people viewed this question
    Top Walgreens Health & Beauty Experts
    Shehu Pro
    Shehu Pro
    Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
