Question about Nokia N70 Cellular Phone
Access point setting - Nokia N70 Cellular Phone
    Problem Solver:
  • 11 Answers
Thats bad
Posted on Sep 07, 2010
Tip
How to set up the PS3 Internet Connection
This setting is available only on PS3 systems that are equipped with the wireless LAN feature.
The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select (Settings) > (Network Settings).
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
6.
Select [Wireless].
7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option Automatic. Select Automatic when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
on Mar 09, 2010 | Video Game Consoles & Games
How to activate gprs on nokia 6300
here is a simple instruction for you to activate your nokia 6300 phone:
1. Go to Menu > Settings > Configuration
2. Choose Personal configuration settings
3. Press Options
4. Select Add new and Access point
5. Fill in a Account name
6. Select Access point settings
7. Set Data bearer to GPRS
8. Select Bearer settings
9. Enter GPRS access point (APN);check your settings.
10. Set Authentication type to Normal
11. Enter User name and Password if requested
12. Back * 3
13. Choose Options and Activate
14. Go Back
15. Set Preferred access point to the access point you just made.
16. Set Default configuration settings to Personal configuration.
17. Select Activate default in all applications and Yes
Nov 08, 2010 | Nokia 6300 Cell Phone
How to set the packet data setting for nokia 5310?
  1. Press Menu
  2. Choose Settings and select
  3. Scroll down screen to choose Configuration and select
  4. Scroll down screen to choose Personal config. Settings and select
  5. Now, press Add (visible if you don’t have a previous Personal Setting created) or press the Options button. when you have pressed the Options button, choose Add New. Then you will have several options to choose from.
  6. Now, scroll down and choose the Access Point and select.
  7. Choose option Access point settings and select
  8. Go into Bearer Settings
  9. Now, choose Packet Data Access Point
  10. Now, enter your APN address corresponding to your operator, then press OK
  11. Now, go back to the Personal Configurations Settings menu (press Back 3 times), where you now should be able to see an Access Point (or called My access point) selected.
  12. Now press Options button, and then choose to activate the Access Point.
  13. Now you should be able to access internet.
Aug 10, 2010 | Nokia 5310 Cellular Phone
How do I set an access point for my multimedia messages(NokiaN70)
access point setting doesnt cost u anything....neither receving a multimedia message...only if u sent a multimedia message costs u depending on operator tariff
u can set up an acces point by 2 ways
1.manually...if only u know ur access point..then u need to go in multimedia settings and enter access point
2. ask ur operator they will sent u the multimedia settings with access point..via text message n u can save that automatically
Sep 21, 2009 | Nokia N70 Cellular Phone
Can' t open WEB
>> check if the "access point you are using is configured correctly.
to do so m go to settings, connections, access points , there you ll find the access points... modify settings of the one which is related to internet and have a blast..
If there's no access point, then either, request you service provider to send u the settings, or you may manually enter settings there, by CREATING NEW ACCESS POINT there , and copying the settings from your friend's fone, who uses SAME NETWORK as yours.. it will work in 99 percent cases....
Sep 13, 2009 | Nokia N73 Cellular Phone
Wap setting for nokia n70
Go to Menu��Settings��Configuration��Personal Configuration Settings��Option->Add New.
Enter details for the following parameters:
�� Connection name: myGlobe GPRS
�� Homepage: http://www.globe.com.ph/globe.asp
�� Access Point Name: www.globe.com.ph
�� Username: <blank>
�� Password: <blank>
�� Used preferred access point:<No>
�� Access point settings:
�� Proxy: Enable
�� Proxy address: 203.177.42.214
�� Proxy Port: 8080
�� Data bearer: Packet Data
�� Bearer Settings
�� Packet data access point: www.globe.com.ph
�� Authentication type: Normal
�� Username: <none>
�� Password: <none>
for mms :
Go to Menu��Settings��Configuration Settings��Personal Configuration Settings��Add new.
�� Account name: myGlobe MMS
�� Server Address: http://192.40.100.22:10021/mmsc
�� Use preferred access point: No
�� Proxy: Enable
�� Proxy address: 192.40.100.20
�� Proxy port: 8080
�� Bearer Settings
�� Packet data access point: mms.globe.com.ph
�� Authentication Type: Normal
�� Username: none
�� Password: none
Mar 27, 2009 | Nokia N70 Cellular Phone
Ps3 help
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
2.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
connectwireless003.jpg 9.
10.
connectwireless004.jpg 11.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
12.
Save your settings.
13.
14.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
If you select [Test Connection], the system will connect to the selected access point.
14.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
1.
2.
3.
4.
5.
Select [Easy].
Select [Wireless].
Select [Scan].
10.
12.
Save your settings.
13.
14.
Hints
Mar 12, 2008 | Computers & Internet
Nokia N70 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
