Question about Pioneer CDJ-100S CD Player
My cdj 100 just turned itself off for no reason and now won't turn back on again. Tried changing the 3amp fuse but that's about all i can do.
Hi there. i am having the same problem. did you find a solution?
Posted on Sep 16, 2010
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
Hi, can advise on the basic procedure in changing
hii,
sorry for late reply, i just saw ur msg here. I have sent u email having pic to micro switch for CDJ. We frequently changes micro switch for Cue button. e30fbde.jpg
i dont know, if u received my email or not.
tx
djajay
Jul 07, 2010 | Pioneer CDJ-100S CD Player
3amp fuse is blowing.
Disconnect the yellow wire from the thermostat and tape off the end. Turn the power back on. If the fuse blows, it is not in your wire nor the compressor contactor. If the fuse does not blow, turn off the power, reconnect the wire, and replace the fuse. Then, disconnect the wire from the compressor contactor and tape it off. Turn the power back on. If the fuse blows, it will eliminate the compressor contactor coil and will likely be a "short" in the wire itself. The yellow wire goes from your T-stat to your air handler and from your air handler, it goes to the oudoor unit's compressor contactor.
Apr 07, 2010 | Weather King 10PJA2501AH Air Conditioner
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
Pioneer CDJ-400 won't turn on.
sounds like a fuse, is the red stanby light on? if it is and it wont power up , then you may have blown the thermal fuse in the main power transformer
Jul 11, 2009 | Audio Players & Recorders
CDJ 800 not working due to Voltage Selector?
What do you mean you changed the voltage? Why would you think this would work? What were the voltage settings originally, and what did you change them to?
If you had too much feedback or distortion, your gain was probably too high, or you had the recording volume on your PC set too high. This has NOTHING to do with voltage. The voltage setting on these units is strictly for 120V or 220V use. Meaning, it can be uses just about anywhere. If your unit is not working, it's because you probably fried the power on it. Are you in Europe, and you tried to set it down to 110/120V? If so, you surely fried it.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Dec 27, 2008 | Pioneer CDJ-800 Turntable
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
Plugged cdj-800 and mixer into a European outlet-now they won't turn on
ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
Aug 11, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
May 06, 2008 | Pioneer CDJ-800 Turntable
The whole system won't turn on
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Jan 11, 2007 | Logitech Z-5300 Computer Speakers
Pioneer CDJ-100S CD Player Logo
108 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
