Question about X2Gen MG19MY 19" LCD Monitor
I have a X2gen 19" monitor, it comes on sometimes but veryfew times most of the time it's just black, is it the monitor or something else.
  • 11,361 Answers
More likely to have dying power supply due to bad DC filter caps, that will be the first thing to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Sep 07, 2010
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
X2gen mw19u 19'' widescreen monitor going black
Try your monitor cable connections on both your pc and into your monitor.
Make sure they are TIGHT and level.
Also, it could be your video display card is faulty or your video display drivers are corrupt.
Try setting your desktop to a lower resolution, like 800x600 and see it that helps.
Nov 19, 2008 | X2Gen MG19MY 19" LCD Monitor
X2GEN 19" Monitor
becauce of overload such a problems are come please disolder path of an eht and look whether smps gives output or not if smps gives output contineusly then replace eht
Oct 27, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor area black
Please refer to the solution I just posted on the other problem posted in regard to this monitor.
--- Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer or perhaps through a credit card company, this would be your best recourse. My experience with this type of issue is that the hardware has gone bad. Particular with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
Thankfully you have another monitor, so you are not left with no display device, but I am sure if you are using 2 monitors, there's a good solid reason and need for it. The other problem posted did not indicate that you were using 2 monitors, and so this presents one remote possibility. Try to switch the 2 out - move them between ports. If the "good" monitor continues to be good and the "bad" monitor still displays the same issue, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not, in other words, if you see something go wrong with the good monitor or the bad monitor improves upon the switch, there could be a graphics card/driver issue that we could work on.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa! (Also, I would be very interested to know what does happen when you switch the two monitors... Thanks!)
May 29, 2008 | X2Gen MG19MY 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen monitor
Hey I've read about your problem cus I had same thing weird lines flying on the screen from one to the other side or crossed and I've found the solution ,there is not enough power strength coming to the monitor power supply because you have to many thong plugged to the same splitter ,just unplug the monitor power supply from this splitter and connect it to another power outlet ,not the same ,another and it should fix the problem at least it fixed my so good luck ,and sorry for my spelling cus I'm Polish ,but I'm trying!
Jan 24, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
