Question about Refrigerators
Defrosted for 48hrs, just started and it is not feeling real cold.
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
Top 2 shelves not freezing
the air leaking into your freezer has caused your evaporator to overice, restricting airflow/fan blade from circulating the cold air.. the unit is now working under gravity where the cold air produce falls pushing the warmer air to the top hence the defrosting of upper shelves... the only solution for starters would be to shut the appliance down for 48hrs minimum so that it can defrost itself manually. Unless you could get a pro to remove the back panel do it. I say a pro as there are sensors and thermal fuses behind it and being temperature dependant can be ruined if not done right plus defrost heater could be tested a another possible cause...
Dec 22, 2009 | Kitchen Appliances - Others
Freezer does not freeze fast enough, icecream gets very soft. The refrigerator is set on temperature level 9 and is not cold.
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Apr 25, 2009 | GE GTS18ABSWW Top Freezer Refrigerator
Help in North Carolinia
if you look inside the freezer you will see frost on the back panel of the freezer, you ar defrosting manually, the issue is either a defrost heater a defrost therinastat or a defrost timer, the timer is an adaptive defrost timer and is in the fresh food section of the ref, gut feeling is defrost timer but one of the three, a ohm meter will tell you if the heater and the thremastat are good if so the timer is the problem
May 20, 2008 | Frigidaire FRS26R4A Side by Side...
Losing Cooling
manufacture/ model helpful. can you find timer???most newer refrigs use control boards. assummong you have a timer advance it to turn into defrost (turn real slow it'll click off compressor) is it really hard to turn(feel like its sticking or turn easy??? should be a smooth turn. If enterd defrost and after 2 min you still dont hear heaterkickin on . id ck defrost thermo. located on evaporator. when cold enough the thermo should test" closed" on an ohm meter and the heater should also be closed circuit.
Mar 06, 2008 | Refrigerators
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Kenmore 5022 please help
Do you have a heavy frost on the rear panel of the freezer section? If so, you have a defrost system problem. If you will post the complete model number I can help you diagnose which part you need to fix it. In the meantime, you can manually defrost it and it will work for about a week or so until the frost builds back up.
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
