Epson Aculaser C1100 Printer
Problem for Epson Aculaser C1100 Printer
Epson Aculaser C1100 PRINTER
By Kagia on May 13, 2008
Dear Sir/Madam,
I've the above mentioned printer which developed the below indicated error after preventative service maintenance "Jam MP E" , this error occurs once you send a document. The printer is able to sensor there are papers on the tray but once you command it to print, it cant pick paper.
I've an experience in the techninal maintenance field but i need you advice regarding the above. whether you can resent the motor timer etc.
Thanks in advance.
My Email address: pkagiah@gmail.com
Regards Patrick,
from Nairobi, Kenya.
Solution #1
posted on May 23, 2008
Not Rated)
labatt
Rank: Master
Rating: 91%, 26 votes
Something went wrong during the maintenance. thereby issuing a false alarm
1.remove the toners,PCU and give the printer a good blowout.
2.using surgical spirit with all covers open, trace all photo sensors within the printer and wipe them clean.
Most likely during the preventive maintenance soot/toner/dust particles settled on the photo sensors which can be found inside the printer as well as on the teflon papper region
labatt
Was this helpful?
Yes
No
Popular Solutions for Epson Aculaser C1100 Printer
Questions and Unsolved Problems for Epson Aculaser C1100 Printer
Do you recommend Epson Aculaser C1100 Printer?
Answer
Answer
Printing several pages in black results in 'ghost' print - tried cleaning printer head with blue... (More)
Answer
Toner cartridge will not clip/fasten in
Answer
C1100 getting MP tray and cover E paper jam message from epson status Monitor (as well as low toner... (More)
Answer
vertical lines in photo copy and scanned documents anytime you put documents through the top portion... (More)
Answer
toner build-up on fuser unit why? what to do? I get build up of toner in lines on the fuser transfer... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , PA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
