Question about Sharp Office Equipment & Supplies
My sharp copier is 2530 model, is flashing F2 and is not coping
  • 26 Answers
Hello, was not made the first installation.
the error should be F2-40, you enter the Developer
hello valerio
Posted on Sep 07, 2010
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I am using Sharp Copier Model no: AR-5320 and when i replace catridge it showing F2 Please give me the solution?
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Dec 30, 2010 | Sharp AR-5320 Black and White Copier
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
System error (f2-04) for model #AR 168S
f2 codes all have to do with the drum. have you replced the drum lately?
Dec 28, 2009 | Sharp Office Equipment & Supplies
Our copier sharp model sf 2530 has error code H5?can't find what this
Clear jams in the fuser unit (heat rollers) then enter these 4 keys P,=,C,= enter simulation number 14 press copy button and follow screen instructions. If none press CA key to exit.......copier may have already restarted.
Nov 22, 2009 | Office Equipment & Supplies
Black copies
lay an original on the glass and make a copy, see if the lamp under the glass stays lit as it scans the original. Don't look directly at the light, it's very bright.
Apr 24, 2009 | Sharp Office Equipment & Supplies
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
May 22, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
May 01, 2008 | Sharp AR-163 All-In-One Laser Printer
131 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
