Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Printer DCP-135C not working and showing Ink empty black on LCD despite new cartridge insertion
worldvet
  • 859 Answers
SOURCE: Printer will not read ink cartridge
This is a common problem in the Epson line. You may attempt to resolve this first, by powering off the printer. Then remove the power cord and leave it unplugged for an hour. Then plug it back in and power on the Printer. The error may reset itsefl on its own.
If it doesn't please refer to this Tip Page on how to obtain and use a utility to reset your Epson. Even if your printer is not listed as those this will work with this method usually will work today.
If you have any trouble getting this resolved please contact me by using the Comment Box bleow.
Regards,
Worldvet
Posted on Nov 12, 2008
Dipu007
  • 2110 Answers
SOURCE: Hi, my Brother DCP-115C Brother
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Posted on Dec 11, 2008
the kowalski
  • 86 Answers
SOURCE: brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Posted on Jun 03, 2009
  • 6 Answers
SOURCE: Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Posted on Dec 17, 2009
  • 526 Answers
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Posted on Dec 19, 2009
My problem is that the printer is not recognising that the cartridge in inserted...it tells me "no cartridge" and also "ink empty", i have put 2 brand new cartridges in and it still...
reset the waste ink counter, put black tape on critical ridge of all cartridges and refilled them. All showed full. All was well for 2 sheets, then all 4 cartridges are showing as near empty on LCD also on software monitor program. Whether or not they are near empty, how does the printer know with the light beam blocked? I have made filling holes on each cartridge (sealed with rubber plugs) so that I can refill without removing them. Doing this is not going to change the readout.
My expert TIP: Buy a new printer. Printers today are as just as expensive as a set of printer inks. Printers have heads and they get dirty over time and might need replacement, which is all the more expensive. Try buying ink advantage printers, they DO indeed save money. Or try looking for somebody who knows how to modify your printer to a CIS (Continuous Ink Supply) printer.
Mar 03, 2011 | Brother DCP 115C All-In-One InkJet Printer
Black ink problem
Replace the _empty_ "black" ink-cartridge.
Or, run a "head-cleaning" cycle, using the software that came with the printer.
May 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
In which case you need to return it and get a replacement.
Mar 07, 2010 | Brother DCP-385C Stylish Colour Inkjet...
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
I cant get the black print,after putting a black cartridge in,can you help please...brother 135c
Dear sir.
If your black cartridge is original
then it is problem printer black ink head
change it and buy a new one
Thanks
Tareq
Aug 26, 2009 | Brother DCP-135C Flatbed Digital MFC...
Brpther DCP 330c does not recognise new black ink cartridge
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
DCP-135C
I have ink in my printer. But it doesn't print. always it displays the message INK NEAR EMPTY. how can i rectify that problem?
Jun 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
50 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
