Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 06, 2010
SOURCE: will fill water but agitator wont run.
you have a broken motor coupling if you want to tackle this your self then reply to this message and i will tell you how if you have to rate me to reply then give me 4boxes im not sure how this site works you can do it if you like to tinker
Posted on Jan 01, 2008
SOURCE: -no agitation
Hello
Welcome to Fixya
My name is Huum,
All functions operate normally except the machine will not agitate.
The agitator is driven
by a couple of different methods. The first is the agitator is splined
and slips onto the matching splines of the agitator shaft from the
transmission. The second is the use of a bell coupling which is splined
to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch
the agitator shaft to see if it is working properly. This wil require a
small load setting of water and the machine set to run. If the agitator
shaft is working properly, it is either the splines on the agitator or
the bell coupling that is defective. If the agitator shaft does not
work properly, the problem is in the transmission.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 16, 2008
SOURCE: kitchenaid top load washer wont agitate or spin
Perfect answer from Flyingtarzan. I just fixed this problem myself and sure enough I had a broken drive coupling. About 30mins to repair.
Posted on Apr 30, 2009
SOURCE: does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
Posted on May 29, 2009
SOURCE: wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on Jun 01, 2009
Apr 11, 2014 | Hoover Washing Machines
Sep 24, 2012 | Hotpoint Washing Machines
Feb 16, 2010 | Washing Machines
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 25, 2008 | Washing Machines
