Question about HP ProBook 4510s FM849UT Notebook
How can I change CDROM drive? - HP ProBook 4510s FM849UT Notebook
    Guru:
  • 689 Answers
Should unscrew unless its moulded into the case,should be screws,need special set of fine screwdrivers
Unplug cable remove /replace
should be user servicable..unless
Posted on Sep 06, 2010
My buffola hard drive is being recognized as Buffalo Virtual Cdrom USB device I have changed cable also went to another computer still seeing it as CDrom
Virtual Cdroms are used to provide the computer with drivers. As soon as the driver is installed, the Cdrom should disappear and the harddrive should be revealed. Windows used to autostart the Setup utility, but since this is a security risk, this was disabled.
You should try to manually run the setup or switch to a drive that is supported out-of-the-box.
Jan 02, 2014 | Buffalo Technology Buffalo Hd-pnt1.0u3r...
The dvd/cdrom drive on my pavillion laptop is not
go to start -> run here in the run box write devmgmt.msc This will lead to device manager here in disk drives or sata-ata remove ur cdrom driver by right clicking it and choose uninstall. This will uninstall the drivers for cdrom and now at the top where ur computer name displayed right click on it and select scan for hardware changes. It will automatically install drivers for it.
May 06, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I replaced my hard drive and now PC says it can't
Hello Friend,
Please change HDD jumper from "Master" to "Slave" as shown in below picture.
Thanks & Regards,
Viju
Apr 02, 2010 | Computers & Internet
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
The CD-ROM (Drive:G)
First check it is detected in bios,if not check the power and data cables to the cd rom from motherboard.If its ok,this is a driver problem.I Think the vendor has given you  a cdrom nero.First boot from a windows 98 cdrom,after that put the nero cd .You can find one folder "driver" or "cdrom",change into the directory and install.Reboot your system it will be okay.
Nov 26, 2008 | Microsoft Computers & Internet
Ilunable to read from hard drive or cdrom from p4i65g
Try changing the IDE cable which connects your CDROM to motherboard. Also make sure that Master/slave configuration are properly set if both the hard disk and the cdrom are connected with a single cable
Nov 25, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Will not find CDROM drive
you should update your BIOS. http://support.necam.com/Drivers/index.cfm?M=547
for WIN98 you want version 28.... version 30 is for win2000
Nov 14, 2008 | NEC Versa 2760MT Notebook
I INSERT CD DISC NOTHING HAPPENS
Hi there
Thanks for posting your problem on fixya
IT seems that problem your cdrom drivers please go to device manager >> right click on my computer then click on hardware then click on device manager double click to cdrom and uninstall cdrom drivers then reboot and reinstall cdrom drivers. Your cdrom working fine
Don't forget to vote me
Thanks
Robert
Sep 26, 2008 | E-Machines eMachines Desktop PC
CDROM Not support for 945 GCNL intel Board
Hey there shivanand, the problem you have seems to related to the bios setup. Try restarting and entering setup page when prompted (F2). Search for the boot sequence setting and enter it. Adjust your setting to have your hard drive as primary boot device. Save the changes and exit to continue setup. Hope it helps. Good Luck!
Jan 28, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
HP ProBook 4510s FM849UT Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
