Question about Kenmore Kitchen Ranges
We have a kenmore Electric range model # 665.92012100. When we press the bake button the digital display is blank on part of the numbers,makeing it very dificult to set teh temperature. Is there something that can be done besides replacing part # 8273639. The cost on this part was listed at $269.00. The numbers on the clock work fine. The controls for the oven work fine.
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
SOURCE: Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Posted on Mar 17, 2008
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
huuum
  • 750 Answers
SOURCE: My maytag oven's clock won't
Hello roborrob,
Welcome to fixya,
You said, Your Maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
What is the model and year of your range?
Try to turn off the rage and then throw the breaker of for 5 minutes and then see if this sresets the system.
How long has this been going on?
Or did it just start ?
And how log have you had this range working fine!
Huuum
Posted on Oct 06, 2008
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
I have a kenmore electric range model #790.9414 and after setting the proper time and hitting start, the time display goes blank after a few seconds and must be restarted.
This is a "feature" imposed upon us by those energy-saving freaks and environmentalist-wackos. What you need to do is press and hold the clock button for 12 to 15 seconds. When you first press this button, the display will appear. Then in about 7 or 8 seconds it will disappear. Keep holding it for 12 to 15 seconds until it re-appears. Now if you release the clock button, it should remain on.
Sep 23, 2014 | Kenmore Kitchen Ranges
I AM GETTING A ERROR CODE ON MY STOVE SAB OR SA6 HOWEVER NONE OF THE BUTTONS WORK
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
On a sears kenmore electric range 790, my mom accidently held the time of day display off by pressing the clock button and holding for more that 15 seconds. (page 13-bottom, if you have a manual). She...
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
Oct 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Why want my kenmore gas stove w/digital display, bake temp not go any higher than 260 degrees?
Check to make sure the display is not in Celsius degrees. Change it back to Fahrenheit for accurate reading.
Dec 07, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
65 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
