Question about Roper RT21AKXKQ Top Freezer Refrigerator
My freezer is dripping water down to the fridge. What do I do?
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Eaton's Viking Model 1266F fridge leaking defrost water
Your idea/plan sounds pretty good. There is a drip pan under the fridge right? it might be a good idea to run it into that. Good luck!
Jul 26, 2014 | Viking Refrigerators
The freezer (top) works fine but water leaking in the fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 31, 2010 | Refrigerators
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
Dripping from freezer
WATER DRIPPING FROM THE FREEZER DOWN TO THE FRIDGE SECTION MEANS YOU HAVE A CLOGGED DRAIN, WHEN THE FRIDGE GOES INTO DEFROST CYCLE, IT MELTS THE ICE FROM THE COIL, THIS WATER HAS TO GO DOWN THE DRAIN TO THE TRAY LOCATED UNDER THE FRIDGE BY THE COMPRESSOR, BUT SINCE UR DRAINIS IS FROZEN, THE WATERS HAS TO FIND ITS WAY OUT SOMETIMES DRIPS TRU THE AIR VENT, AN RUNS DOWN TO THE BOTTOM OF THE FRIGDGE SIDE, AN WHEN YOU OPEN THE DOOR YOU WONT SEE IT, BUT U WILL NOTICE THE WATER ON THE FRONT LATER U JUST WONT KNOW WHERE IT CAME FROM...!
IF THE FAN IS NOT RUNNING YOU MIGHT HAVE TO REMOVE THE PANEL ON THE FREEZER SIDE AN SEE WHAT IS GOING ON, A BAD DEFROST DRAIN CAN CAUSE ICE ACCUMULATIONS TO THE POINT WHERE THE ICE WOULD BE SO MUCH AN NOT ALLOW THE FAN BLADES TO SPIN, CAUSING THE FAN MOTOR TO BURN, AN OVERHEAT , BUT THE PROBLEM WOULD BE THE DRAIN, AN THE WATER YOU SEE IS THE WATERR THAT MELTS FROM THE DEFROST CYCLE
Feb 01, 2010 | Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
48 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
