My acurite beeps all the time. how can I get it to stop?
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Need User manual
I cannot find your model L50668TX thermometer on Acurite's website. That said, you can search available product manuals here:
http://www.acurite.com/kbase
Alternatively, if you still need more assistance/User Manual information, you can contact them with these details:
Website: http://www.acurite.com/support
Customer SupportTel: (877) 221-1252
Mon - Fri:
7:00 a.m. - 7:00 p.m. CT
Sat - Sun:
8:00 a.m. - 4:00 p.m. CT (Oct - Feb)
spacer.gifWholesale(866) 249-1045
Mon - Fri: 8:00 a.m. - 5:00 p.m. CT
support-mail.jpgMailing Address
Chaney Instrument Co.
965 Wells St.
Lake Geneva, WI 53147
Email: info@chaney-inst.com
Apr 16, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Aug 25, 2011 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
I need to reset the time and do not have the instruction manual.
I Have a Acu-Rite Acurite Wireless Weather Thermometer 604RX and it came without an instructions for use. Is there any web site I can go to in order to get the instructions or could you e-mail them to me? Thanks, Pat
Apr 26, 2011 | Acu-Rite Acurite Wireless Weather...
My acurite inside unit keeps beeping every 5 minutes, please tell me how to stop it. it is 22 F outside right now and I think it is a freeze alarm Mike Doty
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Feb 10, 2011 | Acu-Rite Acurite Wireless Weather...
I don't know how to turn off the alarm.
The manual is at http://www.acurite.com/manuals/00604A1-instructions.pdf
To turn the alarm on and off 1. press the alarm button momentarily. 2. Press the "+" button momentarily once or twice. The alarm indicator (looks like a bell) to the left of the time numbers will change from on to off.
Jan 06, 2011 | Acu-Rite Acurite Wireless Weather...
My acu-rite keeps beeping even after a battery change. Why?
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Nov 11, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
46 people viewed this question
jasbo
jasbo
