Question about Kenmore 42722 Top Load Washer
Kenmore 42722 Top Load Washer (portable) what type of aereator goes on the faucet?
SOURCE: Whirlpool Kenmore 2.1 cu. ft. Compact Portable Top Load Washer
did u try leaving the lid pushed down? I just had the same problem and had to push down on the lid in oirder to get it to work and leave it pushed down during the entire wash, it was quite a pain
Posted on Jun 30, 2008
SOURCE: Kenmore top load washer counter balance spring
There's a nice picture here.
Posted on Feb 20, 2009
graemevm
  • 519 Answers
SOURCE: kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Posted on Jun 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore top load portable washer leaking, model 110.42722200
Replace the water pump. The seal is leaking.
Posted on Jul 16, 2009
  • 1937 Answers
SOURCE: it is a door switch for Kenmore 80 series top load
I'm not sure what your question is but following is the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.25842400
If you look in the top and cabinet section, you'll see a description of the Lid Switch.
If you need to replace it, you'll have to remove the cabinet first.
Following is a site with a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=534500897c8bf705d91c620362438f0e
Posted on Nov 01, 2009
Water Pressure from the faucet isnt that strong
You could have some blockage in the aereator. Remove and clean aereator. There could also be some blockage in the supply lines. Make sure you have adequate pressure at the stops.
Aug 08, 2011 | Ldr Industries Plumbing
Model # 44722 Portable Washer Are you suppose to open washer to balance load while washer is in spin? I did and the tub stopped abrutly moveing the machine about 1 foot across the floor.
a safety mecanisim built into washers is the top lid switch it detects when the lid has been opened if you do this whilst its spinning it will engage a powerful brake as you saw to stop the barrel so you dont reach in and loose an arm its perfectly normal. if the washer goes unbalanced wait turn the power off at the wall wait till it stops spinning then re arrange the cloths
best of luck
please take the time to rank this advice
merry christmas
Dec 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Valvers are open and no kinks in the hose still have slow water flow
The first thing I would do is remove aererator from spout outlet. It should not be on very tight so you may be able to remove it by hand. If you are standing in front of faucet turn aereator clockwise or to your right to remove. If you cannot get it to turn wrap aereator with masking tape,duct tape or rag to keep from marring finish and use channel lock pliers or standard pliers to remove. There should be one or more brass or stainless steel screens and possibly a brass disc with a small hole in center. Also there should be a rubber washer that goes between faucet spout outlet and aereator. With all these removed , see if flow rate is improved. Carefully clean screens and disc. Reassemble in reverse order. Hope this helps.If this dosn't improve flow rate you may have to further disassemble vavle to find source of blockage. Thanks
Nov 11, 2010 | Price Pfister T26-4CBY Avalon 4 Hole...
My kenmore portable washer, washes but does not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine problem
Possibly your timer or a motor
Aug 28, 2008 | Kenmore 22422 Top Load Washer
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
Kenmore 42722 Top Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
