Will not boot. The following (All greek to me) takes up about 1/2 of screen. toshiba hardware set-up Select pointing devices click simultaneous c0000221 bad image check sum shell 32. dll poss corrupt
  • marsrs1 May 13, 2008
    So far what I appreciate the most was your quick turnaround
    answer. At this point I am not qualified to give your comments a proper evaluation. Thank You very much ! ....Mario Rivas
  • 3,940 Answers
The C0000221 error indicates a problem with the Windows File system.
http://support.microsoft.com/kb/314474
This can often be caused by a failing hard drive. If your system has built in diagnostics (F12 at boot on many systems) you may be able to run a diagnostic there.
Posted on May 13, 2008
Need drivers for this mouse
You can either 1) re-install the driver, or 2) roll back the driver. Either one of these may help. To roll back your driver in Windows XP, go to Start --> Settings --> Control Panel --> Mouse. Click on the "hardware" tab. Select the appropriate pointing device, and click "properties." Click the driver tab, then select "roll back driver."
Under the "hardware" tab, there may be more than one mouse. If this is the case, select the one that is not used, follow the settings above, and then select "uninstall." Or, you can go into Control Panel --> System --> Hardware --> Device Manager, and remove the device under "Mice and other pointing devices
Jan 18, 2014 | Kensington PilotMouse 72129 (DH72129)
Toshiba satellit L875d-s7332 froze during factory recovery now says no bootable device
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 05, 2013 | Toshiba Satellite L875ds7332 Notebook...
How do I take my pc back to factory settings
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Dec 31, 2012 | Toshiba Satellite P105-S6197 Laptop
"For Atheros PCIE Ethernet Controller v2.0.2.3(05/18/10) Check Cable Connection!"
The operating system is looking for a boot device
Make sure there are no discs in the drives cd/dvd and usb
make sure the bios is set to boot from your hard drive or
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
hope this helps
Nov 25, 2012 | Computers & Internet
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Toshiba X205-SLi4 went through one of those updates where it has to do 1 of 3, 2of 3 etc configurations. Then it rebooted and now we have no monitor. You can tell it is on, but nothing comes upwhen the...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used?3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status").7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 23, 2010 | Toshiba Satellite® X205-SLI4 PC Notebook
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
Windows xp won't boot up and i end up getting this blue screen with the a stop error on it...
Sometimes BSOD are caused either by Software or Hardware problems, you can start running the diagnostic test first on the computer to check for hardware problems.
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Follow on screen instructions
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Solution will be restoring it back to factory settings.
1. Turn on computer
2. Tap F8 continuously on the Dell logo screen
3. Select Repair computer
4. Follow instructions... then select "Dell Factory Image Restore " on the recovery options
5. Follow instructions
6. Wait for 20-25min. and computer now is back to factory settings
Hope this helps
Dec 17, 2009 | Dell Inspiron B130 Notebook
I keep getting the message 'no audio output device'
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Jun 28, 2009 | Toshiba Satellite U305-S2812 Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
