Question about Kenmore Dishwashers
Our dishwasher is leaking at the front side of the dishwasher. It looks like it is coming from behind the door.
    President:
  • 1,430 Answers
This is probally coming from the soap dispenser seal. The seals are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/dishwasherdispenser.html
Posted on Sep 06, 2010
Leaking door
Open the door and look inside at the lower left corner where the door gasket ends. See if there is any type of obstruction or foreign object in that corner. It doesn't take much to cause a door leak. Some door latches can be adjusted tighter. Look at the top door latch system and see if has 2 screws in it. You can sometimes loosen the screws and push the latch inward slightly and re-tighten the screws. That will make the door tighter when latched. Not all dishwashers have adjustable latch systems.
Apr 04, 2015 | Dishwashers
Leak on the side of the dishwasher - help please....
lets step back and take a look at this,this is the way a dishwasher works.1water in.2wash.3water out,that it.i just cant see this hose going up and down a rule the water goes straight out via the pump.let me stop you there and say follow what i have said and go back and have a good look and come back to me on this problem and i will help you.adrian,,,
Jul 02, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher leaking from the door
Might want to change the door seal if its coming from the door.
Dec 30, 2009 | Hoover 24 in. HD83M Free-standing...
The new dishwasher kitchen aid we bought is leaking
If it is leaking from the front, then there is a problem with the seal that runs around the front of the dishwasher. It is usually located behind the main door on the edges of the unit itself, it will look similar to weather stripping. A cheap way of fixing this is to get real good weather stripping from Wal-Mart, Home Depot, Lowes, etc. It will have a sticky surface on one side, you peel off the paper, then apply the weather stripping to the actaul door, first try to mark where the old one sits against it.If its leaking from underneath, than it can be a number of things, but most are easy to repair, you just have to pull the dishwasher completely out to get a better look. Sometimes one of the components will be leaking, but for the most part, it might just need a new hose clamp or tightened up. Hope this helps.
Dec 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Where do I find the serial number for the Kenmore Ultra wash III dishwasher
Look at following areas for the model number
* On Right Hand Side Of Upper
* Front Tub Or Door Jam
* On Flange Behind Dishwasher Door
* Behind Latch Strike
* Upper Left Corner Of Frame
Jul 19, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Maytag Quiet Series 300 Dishwasher leak
hi there,
the leak may be coming from the door gasket or the door vent.
can you provide me with the complete model # please?
Sep 21, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
