Just bought a new 120gb Maxtor HD ATA/133 to replace my old 40gb HD which burned out. The new one has 5v and 12v both at 590 ma each.The old one has written on it, 5v at 559 ma and 12v at 601 ma. Will the differences in these milli-amp rates be a problem? Thanks, Sid
    Genius:
  • 1,226 Answers
There is no problem about that only the speed of the hard drive differ, try see if same rpm. If the system recognise then there no problems.
All the diffencies are tolerable.
melnavz
Posted on May 13, 2008
    Problem Solver:
  • 11 Answers
If you have an EIDE Hard Drive, it has a Molex port for power. It is universal. You are fine, make sure the Jumpers are set correctly if you have more than one Hard Drive on the same IDE channel, format and install the OS!
-MM
  • 3,940 Answers
Differences of amperage this minor will not make any difference. As long as the System Setup (BIOS) identifies the drive, you should have no problem.
Un maxtor diamondx plus 9 120GB ATA/133, lo quiero usar como segunda unidad y esclavo, como debo poner el jumper
to connect as a slave have HDD1 as a master and then HDD2 as a slave you can have these attached to the same ATA connection, of course there can be problems with this, if i were you i would put both to cable select takes away any hassle of getting it wrong
Jan 10, 2014 | Maxtor Hard Drive
Hi my drive will only format as fat, i need it to load xp on it, am i doing something wrong?
No, your not doing anything wrong. The FAT32 file system is for smaller drives while the NTFS is for drives in excess of 100GB.
Oct 16, 2010 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
Is the maxtor 6y120p0 a ata or sata format
Maxtor DiamondMax Plus 9 120GB 7200RPM IDE Ultra ATA-133 3.5-Inch Internal Hard Drive Mfr P/N 6Y120P0
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Diamondmax plus 9 120gb hard drive
IF THIS IS AN ATA TYPE DRIVE (please verify this from you drive's documentation or labeling) -- you may need to review the following link to determine the proper method to install your new drive. This review should also take into account any documentation received with the drive. There are several variations of drive issues that cause the drive to register as the incorrect size described in the link. If you have questions please add them as a comment to this issue and we can review them before you take any unwise actions with this drive. Read the page carefully there are as stated before multiple reasons for this type of issue and multiple resolutions. Seagate acquired Maxtor so this link could be appropriate.
ATA 32GB Drive Issues
Dec 14, 2007 | Maxtor Open Box 120GB DiamondMax Plus 9...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
