Question about Nintendo DSi White Console
Error code 052411-1 We cannot get it to connect to our wi fi at home which has a security code
  • 1139 Answers
SOURCE: i'm getting an error code : 61070 and being kicked
Hi, this is not necessarily anything actually wrong, it is usually an error code given when there is either an unstable network connection, heavy network traffic or even the channel used on your router. If you can, go to your routers settings and try changing the wireless channel that it is on. Give it a little time before trying to connect again.
If the problem persists, give Nintendo a call but I am pretty sure it shouldn't come to that.
Hope this helps and thank you for using FixYa
Posted on Sep 03, 2010
angelo_mlc
  • 1035 Answers
SOURCE: i can't connect my Dsi
Hi. This is a common issue for this console. Try resetting the router, or change the security code / security type.
Posted on Sep 13, 2010
gingerade
  • 70 Answers
SOURCE: error code 051110-1 How and where do you enter
Go onto the Ds game that your going to play wi fi
go to multiplayer
then Wi-fi
then go into settings and it should come up with 3 boxes of connections , click on and go from there :)
Posted on Mar 19, 2011
emr4378
  • 102 Answers
SOURCE: wi fi error code 51099
Error code 51099 implies that your DS cannot connect to the wireless signal. You should check the settings on your DS and the settings on your router.
Here's a detailed and interactive guide for how to do both.
Hope this helps fix your problem!
Posted on Mar 25, 2011
SOURCE: connecting to Wifi at home. Error Code 51102 What
A WEP key is a Security code but for some wireless providors a WPA-TKIP or WPA"-TKIp is used instead. check your connection details to find out which one yours uses and the use the appropriate settings.
Important notes would be that if your connection is using WPA-TKIP or WPA2-TKIP then the DS or DS lite will not be able to connect because they can only use WEP keys. If the system you are using is the Nindento DSi then all you need to do is to use connections 4, 5 and 6 found in Advanced Conection Settings under the internet option in the DSi Settings menu ( remember this method is only for use with other wireless securities than WEP keys like WPA-TKIP and WPA2-TKIP.)
Posted on Apr 07, 2011
How do i connect my Wii U to the internet
To connect a Wii U to your wireless home network:
  1. From the Wii U Menu, click System Settings.
  2. Using the Left Stick, select the Internet icon and press the A Button.
  3. Select Connect to the Internet.
  4. The Wii U will search for available Wi-Fi networks in your area.
  5. Once the search completes, use the Right Stick to scroll up and down through the list of networks and select the name of your Wi-Fi network.
  6. If prompted, use the on-screen keyboard to enter your Wi-Fi network's security key (wireless password) and select "OK" when finished.
    • If you receive an error message stating The security key you entered is incorrect, the security key you entered was not a valid security key.
  7. The Wii U will now perform a connection test.
    • If the connect test fails, select OK to receive an error code and detailed information on why the connection test failed. You can use Nintendo's Error Code Lookup Tool to get information on resolving the error.
  8. If the connection test is successful, select OK to continue.
  9. When asked if you would like to make this your default connection, select Set if you wish this to be your default connection or No if you do not.
  10. The Wii U will now ask you to perform an update, select "Update" to perform the system update, or select "Cancel" to skip this process.
    • Nintendo recommends performing the system update as this will ensure you have access to recently released applications and services.
Aug 06, 2017 | The Video Game Consoles & Games
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
How to connect in wifi
To connect to wi-fi first you need to be in the wi-fi enabled zone (home, office or others). Turn on the wi-fi from your device and then enter the wi-fi security code (ask the concerend person for the code!
Apr 24, 2013 | Cell Phones
My samsung star wifi can not connect to my router
1. Tap the "Menu" button from the home screen of your Samsung Star phone.
2. Tap "Wi-Fi" and select the "ON" option.
3. Select the Wi-Fi router you want to connect to from the list available Wi-Fi networks.
4. Enter the case-sensitive password to connect to a secured network. Your phone will only prompt you to enter a password if connecting to a secured network.
5. Wait while your phone automatically connects to the Wi-Fi router.
and enjoy your wi-fi connection.
Aug 10, 2012 | Samsung S5230W Star WiFi GSM Unlocked Cell...
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
To connect to a WLAN via Wi-Fi™:
  1. From the Home screen, find and tap Settings.
  2. Tap Wireless controls > Wi-Fi settings.
  3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
  4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
Useful tip:
  • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
  • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
  • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
  • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
You can also try updating your softwares by going to the sites below;
Update Service,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
PC Companion,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
Start the program and just follow the on-screen instructions.
I hope this will help.
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
Error code 051110-1 How and where do you enter
go to multiplayer
then Wi-fi
Mar 18, 2011 | Nintendo DS Lite Console
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Nintendo DSi White Console Logo
337 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
